Dalby website has not been active for some years. But the Audio Exotics forum features numerous people taking delivery of and commenting on new Dalby components/cables/accessories.Yes...but strangely the Dalby website actually has only the Preamp on it...and also says 'new website coming in 2011'.
Thanks! Will check that out.Dalby website has not been active for some years. But the Audio Exotics forum features numerous people taking delivery of and commenting on new Dalby components/cables/accessories.
Hi Barry...Ultra 5s swapped out and Ultra 7s in today. Will update later. I also am trying U6 v2 under the Robert Koda amps...unlike the Gryphon Mephisto which was not only inert, dense (but also built on 4 massive feet of some kind of dense inert compound)...the Robert Koda does benefit from isolation. ...very promising so far...more to come...Thanks Lloyd.
Trust you are well.
No I haven't tried the Ultra 7s or heard anything of them other than in this thread. I did have the Ultra Vs under my YG speakers for quite a while but when I mentioned it to Dick Diamond at one of the Munich shows he advised me to go back to the supplied YG supports.
Duly followed his advice when I got back and concluded that he was right.
I appreciate your system is digital but after the success of the V2s I tried the new Ultra 6 turntable clamp in replacement of the stock SME clamp. It made an immediate and significant improvement to the sound.
As to the 7s I am guessing that they have further developed the successful improved technology in the 6V2s so it will be interesting to hear what people think.
Thank you for the update Lloyd.Hi Barry...Ultra 5s swapped out and Ultra 7s in today. Will update later. I also am trying U6 v2 under the Robert Koda amps...unlike the Gryphon Mephisto which was not only inert, dense (but also built on 4 massive feet of some kind of dense inert compound)...the Robert Koda does benefit from isolation. ...very promising so far...more to come...
I have heard the Ultra 7s were designed in some form of collaboration or with design input from Andy Payor of Rockport. One of my favorite audio brands and designers of all time.
Just had a look at them. Look good.
I will look forward to your further report on them and also how the Ultra6V2s perform under your Robert Kodas.
Off topic I know, but the QSA fuses have been a tremendous success in my system.
Hi Barry,Thank you for the update Lloyd.
Hi Cuntigh,Hello,
Reading this instructive thread, I understand that the Stillpoints, supposed to be a « Uber » product ar Uber price needs to add a HRS Nimbus for sounding good !
I have doubt about Loyd but it’s a pity for Stillpoints (IMHO)
Hi Lloyd,Hi Barry,
Magic. The HRS Nimbus (NIA-100) on top of the U6 v2 is the magic combination once again. The detail of the Stillpoint U6 v2 is remarkable...but the HRS on top brings 2 [absolutely mandatory] things:
- the tonal balance in the upper register of piano/strings is now correct-sounding to me...without, I hear a hardening of treble, slight thinning and definitely a shar truncation of the tail-most end of the treble note
- in fact, the DETAIL improves in that those same notes also become more fully fleshed where the END of the note is far more complete...so now you get the benefit of the U6...more organized music, separation of instruments, space, and a far more resolved sense of timing in music...where silence plays as big a part as the music
- plus, you get individual note fullness from the HRS Nimbus sitting on top
Overall, I think that the stiff elastomer element sitting on top of the U6 v2 with its combination of steel and ceramic balls really, really works well.
Separately, so far, the U7s are also impressive in their ability to deliver a more resolved capable sound presentation at both low level and at large full-scale, full-volume levels without the speakers starting to show their vibration-induced limits.
More to come...
Hi Barry,Hi Lloyd,
Many thanks for your feedback and I am glad that both the Stillpoints have proved effective. The U6V2s have certainly worked under my Vitus SIA 030.
As I said earlier the Ygs didn't benefit from the Utra 5s, but my floor is concrete so less of a problem than your wooden floor,,and pleased to hear that the U7s have improved the performance of your Wilsons. Do you have four U7s under each speaker or are 3 enough?
It is gratifying when these additions to your system do make a difference for the better, but you can be completely sure until you are able to try them at home.
Best
Barry
Thanks Lloyd.Hi Barry,
Overall, I think the HRS Nimbus Couplers on their own are 'ok' at best...they work well with HRS M3X shelves but that is a big commitment of weight and space. By contrast, I prefer the Nimbus Coupler/U6 combination a LOT. More compact, easily useable with various components as the system evolves or grows.
I do not use HRS Nimbus Couplers alone anywhere in the system.
AS to where you might try them...Scarlatti DAC yes...Transport maybe...I find that transports are designed with the expectation of vibration already and surprisingly had less strong positive impact from isolation than one might otherwise guess. Regarding Vitus, yes, I would be intrigued to understand what happens if you put the Nimbus Coupler between the Vitus and the U6. Then listen to Glenn Gould Goldberg Variations if you happen to have it. Tracks 2 and 5/6 are my references for how the various notes along the keyboard can sound depending on system setup (and isolation).
I have found power benefits almost 'most' from isolation (power conditioners, power supply units)...and amps. The one exception was the Gryphon Mephisto which was so inert (108kgs) it took a LOT to make even the slightest impact with isolation...and I am not convinced I actually made one...I had extra weight and materials and used them because the earlier reference Colosseum did benefit.
Thank you Lloyd.Barry...just saw this on another thread here at WBF (from an owner and fan of Stillpoints who puts them on top of Symposiums)...see my reply as well. Posts 9 & 10.
Racked With Doubt: Symposium vs. Artesania?
I am new to WBF, and have never posted here before. I typically do not post anywhere, but I have been reading the posts on WBF and have been impressed by the knowledge, experience, and civility of the members who post. I am researching the purchase of a replacement rack for my system and I am...www.whatsbestforum.com
The Dalby Audio Lignum Vitae feet are similar in design to the ASI, but the Dalby are significantly better in every parameter. I have the Dalby under my sacd player and the ASI under its separate power supply.I have two sets of the ASI TopLine footers and I am shocked on how great they are under my Bricasti and Antipodes.
i Am looking to buy more if anyone has a few sets they want to sell.
