Hi Lloyd , you should definitely try lifting your PSU , at times the last piece is like flicking ON the switch , as it was in my case with the U5's under my speakers . My barometer for the Entreq will soar , if you decide to keep it .So do keep us posted . Yes the guys at AE (HKG) are raving about the Signature Troy , even having coined out worldly terms like "resolution of the soul" in describing it's effect , not just plain resolution mind you.... Definitely bears more investigation, yes it does .
Done! Smokes...I put 3 Ultra 5s under the Transport PSU. Done...so done. Got a price break but still insane. Fortunately, the entire system is totally floating from first entry point from wall into Power Conditioner thru source thru preamp thru amp thru speakers and sub...each component floating. Done!
