Symposium Ultra platform vs $69 Auralex Isolation platform
XV-1
3,619
2,629
1,860
Sydney
I had a Symposium Ultra with Stillpoint Ultra's under my DÁgostino Stereo amp for quite a while. the Ultra platform used to be under my turntable, but my $100 granite platform and compression springs had superior results. the Ultra platform sounded nice and was better than the Dag amp sitting directly on the floor.
I then read about Auralex Gramma Amp or Loudspeaker Isolation Platform and @ $69 they were worth a try.
My expectations were low to be honest. The bass was tighter, vocals clearer as well as the mid range and top end more open. Overall a lot better than the much more expensive Ultra platform.
After living with this for the last 6 months, I decided to go back to the Ultra Platform. After 2 tracks I comparison the Symposium was less detailed and overall seemed a homogenised musical presentation.
My wife was helping me here and we put the amps back onto the Gamma and even my wife said the music was so much better sounding now. These $69 Auralex Gramma Amp or Loudspeaker Isolation Platform are going nowhere.
they might be cheap, but give the Auralex Gramma Amp or Loudspeaker Isolation Platform a try and you may save 1000's
Reactions: dubselect
XV-1
3,619
2,629
1,860
Sydney
Thanks for that.How much weight can they take?
136kgs. Since you are in Australia, they retail for $89. Got mine from store dj.
This might not get much air time on wbf as they are too cheap :cool:
Down Under
195
46
333
Perfect.
You've saved me a fortune.
Did as you suggested and ordered from Store Dj
Thanks Shane.
XV-1
3,619
2,629
1,860
Sydney
Perfect.
Thanks Shane.
Don't thank me until you used it. You may not like it ;)
Down Under
195
46
333
I'll let you know.
The Les Davis Audio constrained layer damping discs (made in Australia) made a considerable difference underneath my phono preamp.
Worth trying as they are inexpensive for the improvement they bring.
Available in the US as well folks.
I have no affiliation with the company by the way.
bonzo75
22,643
13,675
2,710
London
I used to use these inner Martin Logans. I found them as good as the 1k Townsend platforms I had
LL21
14,430
2,518
1,448
Totally agree with Auralex. I have the extra large which will take well over 200lbs. It sits under the sub which is also heavily mass damped with over 100lbs of weight on top. We used it under the Gryphon (also 200lbs+ incl mass damping on top). The only reason not to use it under the Gryphon long term is it is tall and thin...it could topple. It now sits on top of Ultra 5s...but the difference was not that massive for a ton more money. But its more that the Auralex is a steal than anything else.
miniguy
437
168
350
San Diego area
Hello, Have you tried resting the Amps on the Auralex Without the Stillpoints in place? If so, what were your thoughts of the differences?
Thanks
I would ask the same. There may be a preference of the Stillpoints for the Auralex, so without eliminating them, this comparison of the two platforms may not tell the whole story.
XV-1
3,619
2,629
1,860
Sydney
Thanks
Originally I tried without the Stillpoints. The Auralex was better sounding.
Having the Stillpoints provides a bit better performance, more with Auralex as it resolves more than the Symposium.
Previous photo without Stillpoints.
thedudeabides
2,195
710
1,200
Alto, NM
I'll let you know.
Another "budget" alternative is the Iso-Acoustics Iso Puck. About the size of a hockey puck and cost $30 per unit. I installed between the shelf on my speaker stand and my Joseph Audio Pulsars. IMHO, a very good value for the money. Available through Music Direct and Amazon with money back guarantee if you wish to return.
cjf
454
105
948
Thanks..I may give them a try also then
Down Under
195
46
333
Interesting to know.
Did you ever try the Auralex with the Antileon when you had it?
LL21
14,430
2,518
1,448
I did not have the Auralex under the Antileon...it started out under my Sub. But when i got a bigger sub, i got a 2nd Auralex and started experimenting with the extra one and discovered it also helped the Colosseum...but over time the weight caused the Auralex to start to lean in one direction which looked dangerously like the leaning tower of Pisa! So i got Ultra 5s and they have been stable ever since.
Down Under
195
46
333
Yes I can understand that a leaning tower of Colosseum is very unsettling.....
LL21
14,430
2,518
1,448
Absolutely! ;) I felt much better once I set it down slowly on the Ultra 5s. Even then, they are quite high, and the distributor is bringing Ultra 6s which he thinks will be better. The best would probably be an HRS M3X platform, but none actually have the weight bearing capacity without customization.
Big Dog RJ
1,255
489
1,155
Melbourne
Yes no doubt these are superb isolation platforms/vibration eliminated!
I had major issues with bass vibration coming from the TT since it is quite close to the right speaker of the Ethos. Was looking all over the place for something that was within realistic cost and does an effective job, my what a marvelous job it does indeed!
Suggested & recommend by Bonzo...
However cost was not under $100, rather it was close to $200 for each platform. I am now using two Auralex Isotone platforms, one for the CD player and one for the TT. The TT also sits on 3 separate Nordost sort kones, this added device eliminates all unwanted vibration regardless of volume levels. The McIntosh mcd301 sacd player and Rega RP3 have never sounded this good!
I highly recommend the Auralex platforms, they will surprise you at what they do, and whatever it is, they work extremely well.
