received more Daiza's, and now have double Daiza's under my Extreme server, and my 3 MSB Select II dac boxes; the 2 powerbases, and the dac itself. previously there was a Tana TS-150 active platform under my dac box, and single Daiza's under the power bases and Extreme.
i am 60-90 minutes into this new thing and it's only good news so far. more textural, more delicate, more detail. more involving and flows better. bass is bigger and digs deeper. quite noticeable steps up......not slight, not huge, but very obvious. and very analog sounding in a good involving way. more organic and full bodied but more dynamic and life like too. the energy projects with a vivid force.
this is removing the active device so it's a very cost effective approach based on the performance i am hearing. Emile told me the synergy of having the whole digital chain sitting on double Daiza's would be quite special and i'm a believer for sure, just waiting to see how far this goes.
i know it takes a day or three for the settling to mostly take hold, and longer than that for the foam in all the footers to settle in. but pretty awesome already.
this brings me to 22 Daiza's in my system so far.
you will also notice i moved the Tana TS-150 to under the CS Port phono pre. i did not have enough height to keep it's Daiza on top, so it just has the 10mm top layer. i was able to use the foam filled small daiza footers instead. i have not yet listened to that....it's next.
