since the bits of data (analogous to a master file or tape) gets converted to dac readable data (vinyl mastering process) by the server, i view the server + data = pressing.
further.....since everyone's data is basically identical; the further analogy is that the server makes a difference like the pressing makes a difference.
two systems with exactly the same data and dac, will sound different with different servers, like two systems playing the same recording, with the same gear, but different pressings.
essentially we have moved on from data being significant. it's not changed in 20 years. dacs are now better. but the big change is servers have matured. they had a very long way to go from the dirty things they were.
In my view the pressing or visceral LP is similar to the digital file you get from Qobuz or Tidal.
The same pressing sounds different with different turntables and so does the file from Qobuz with different servers.
Matt
