Hi Roy,
I may be reading this incorrectly but am I to understand that grounding issues can be affected by vibration?
Geoff
Yes, any audio component with a power source will vibrate. Vibrations result in the creation of unwanted DC. If this DC isn't grounded away, it leaks onto the next component through the interconnecting cable. This is what is referred to as leakage current and is the basis for a ground loop. Unlike traditional grounding devices, a Setchi box is designed to cancel out a component's vibrational energy. Alternatively, if you apply complete galvanic isolation between 2 components such as with an optical connection between the server and DAC, then you prevent this leakage current from reaching the DAC.
In Emile's own words:
"Let me just add the relationship between capacitors and vibration to this discussion.
1) A voltage applied to a capacitor causes it to vibrate.
2) Vibration applied to a capacitor causes it to generate a voltage.
It should be clear that neither of these are desirable traits in our electronics."
https://www.whatsbestforum.com/thre...ion-in-audio-systems.29360/page-5#post-607406
https://www.whatsbestforum.com/thre...is-setchi-is-quite-special.24081/#post-476522
