Through either USB or AES/EBU.Thanks for chiming! How do you connect the Extreme to the TotalDAC? Ethernet cable using an exact bit datastream?
Can one run Jriver in this machine? Any backup program to backup the files to external NAS?
All the RAM used are also proprietary and Emile ordered them with special requests.
Each RAM are carefully measured and are built with matched memory chips to ensure the best performance.
Time permitting I can expand on some technical design choices for those interested.
Addressing memory modules:
One of the largest disturbances on server music playback quality we found is DRAM refresh. The charge on DRAM memory cells weakens over time therefor it needs to be refreshed in pre-set time intervals. During the refresh period all memory operations halt. Memory current draw peaks during refresh, a single memory dim can easily draw 2.5A or higher during the refresh cycle. This is the main reason for DIY community feedback that fewer, or lower speed, dimms sound better, which can be true except you're seriously limiting bandwidth as you have more then just a single memory channel in modern high performance systems.
With the EVO we started focussing on reducing the amount of refresh intervals and refresh period time with quite significant advances in playback fidelity. For this to work you need a higher then average selection of memory chip quality, close chip matching and keep temperatures as low as possible. For the EVO we bought virtually all available consumer level dimms and selected those in which we could get the lowest memory refresh rate / length. As it turned out quality varies from dimm to dimm, so on top of that we started cherry picking the best of the bunch.
For the Extreme we took this a few steps further, these dimms have factory pre-selected A-grade memory modules, all dimm components (memory chips, capacitors, resistors etc) are matched to within a 1% tolerance and selected for low current draw. The side effect of this is refresh rate burst current is reduced by almost 50% and operating temperatures are much lower allowing lower refresh rates. Combined with power supply filtering this allows us to use 12 memory dimms with a very high combined bandwidth at very low refresh noise levels.
What is the advantage of Jplay Femto? Can Jplay Femto be easily added to an EVO?
Thanks
Does it mean that reducing refresh rate and refresh cycle period require Lower CAS value and higher frequency?
Thanks very much for that. Just to confirm, would the dac need to be UPnP/DLNA compliant and act as a renderer?The answer to all questions is yes.
No, you can consider those unrelated settings
Thanks
Of cause~!!
Very easy~!!!
Don't we loose the benefit of most of the specific aspects of the Extreme adding a third party card that streams the data to the DAC?
I have JCAT Femto USB Card and Femto Network Card.
When I use JCAT product to Extreme, sound quality is increased a little.
I don't want to recommend other cards.
But JPLAY Femto is super fantastic~!!!
Am I correct saying that you use the JCAT Femto Network Card to connect to the network and connect to the Trinity DAC using the JCAT Femto USB Card ?
Thanks. Does the Extreme have a master clock input, allowing it to be synchronized with a DCS DAC using AES/EBU?
