Just shows it's like everything, system dependent.I did remove the swiches and it is all ok but not as good as it was . Big step down.
I wish I could just take it out and have both
better music and money back from the switches ....
I'll try copper ethernet again from modem/router to Extreme maybe later today or tomorrow just to hear for myself.
Well, the installed copper ethernet run is good quality generic and has molded plastic terminations at both ends rather than fancy metal connectors. So if it is shielded there is hopefully no complete path through the shield via the connectors.It’s early days with TAS, but there’s mounting evidence towards UTP cable screens being quite harmful. If you do try this, do try an unshielded UTP cable or atleast one with a “floating” shield.
It would not be very surprising to me this is actually a big advantage of Fiber. We’re all used to using cat6/7/8 shielded cables. The signal carrying conductors are transformer decoupled but the shield is not, or it may just act as an antenna as its directly connected to the server chassis (and usually the switch chassis).
Steve Z
How is well is WiFi likely to work with TAS?
Whew, so I didn't waste the money spent on electrical engineering courses after all!All plastic connectors qualify as non conductive
Emile, in the UK we are stuck with our commercial routers, we cannot swap them out for more advanced alternatives.Something like a netgear Orbi does seem to perform quite ok if spaced away from your system.
I think I must be the only Extreme user that uses wifi to stream from my Orbi router downstairs to an Orbi satellite upstairs in my sound room.I then run Ethernet from the satellite to the Extreme. Contrary to everyone's advice not to have this near my audio gear, mine is sitting directly behind my amps and there is zero noise in my systemEmile, in the UK we are stuck with our commercial routers, we cannot swap them out for more advanced alternatives.
The router in my house is 50', and one storey, from the audio setup.
Yes that might be a reason.Just shows it's like everything, system dependent.
You’re not the only heretic here Steve as I do the same in the interests of domestic harmony.I think I must be the only Extreme user that uses wifi to stream from my Orbi router downstairs to an Orbi satellite upstairs in my sound room.I then run Ethernet from the satellite to the Extreme. Contrary to everyone's advice not to have this near my audio gear, mine is sitting directly behind my amps and there is zero noise in my system
A C7 powercord! nice touch.
Hmm, the more modern WiFi access points will have this type of tech and likely to be pushing out less power when nearbyas someone who works on wireless communication, i'm terrified
its a good thing the extreme is a virtual faraday cage!
is the wifi access point reasonably nearby? if so, power control and beamforming antennas could be keeping the transmitted power low.
Don't hold back! Tell us how you really feel about Roon!Roon has very dirty bass sounds.
If you hear this system directly, you will not be patient for Roon's idiot dirty bass sounds.
Is 50ft away, which is why I’m doing this to save traipsing 20m of ethernet cable along the hallway. I did a comparison against being hardwired with a long run of my own Sablon ethernet cable a couple of years ago and the wifi sounded better. Go figure.as someone who works on wireless communication, i'm terrified
