Has anyone found a way in TAS to simply add a track (Playing or in Queue) to an existing Playlist?
Popping in to read all the positive comments about digital I wonder how many folks were die - hard vinyl fans previously slamming digital as inferior (and doubting my prediction) might now change their mind as to their choice of source listening. ;-)
And it will only get better and cheaper. Vinyl is great as a source @$30K and above. If your source budget is less look no further than digital IMO and IME. And happy listening as always!
Pretty big gap still imo. Each has its place I guess.Popping in to read all the positive comments about digital I wonder how many folks were die - hard vinyl fans previously slamming digital as inferior (and doubting my prediction) might now change their mind as to their choice of source listening. ;-)
Thanks for the suggestion, but unless I'm misunderstanding something (not unheard of), I think your suggestions just allow me to add a track or album to the queue. I'm looking for a simple way to add a track from the queue (or Playing screen) to an existing Playlist.go down to the track level, hit the 3 dots at the right, and select "append to queue" to add a track
to add an album, go to track level and hit plus sign inside circle to add all tracks on that album
Who said you need $50K to get great digital? And compared to what?My guess is that the vast number of people who own an Extreme have over $50k invested in their digital front end. Digital sound can be great but it isn't that cheap to get it.
Depends on the quality of the implementation ;-)@dminches How do you define great digital? I guess it all depends on your expectations and capabilities. What one person considers satisfactory is often deemed unacceptable by another. Some listeners are happier with their $2k DAC than those with their $50K one.
There is no common denominator for satisfaction. The realm of audio is very subjective. Of course there are measurements and the more expensive a product the better the specs hypothetically (as a rule of thumb) but does the higher price and subsequently better specs automatically translate into a greater product?
Where did I say you need to spend $50k? You are the one who started talking about $30k analog in a thread in which the gear being discussed cost $30k without a DAC.Who said you need $50K to get great digital? And compared to what?
