Great info! No one at this level should use a switch mode power supply.
I’ve been using Teddy Pardo supplies with great results for years.
The main point, which many have already heeded, is that if your ISP modem does not use a LPS, try to acquire one that does. The difference is easily heard and is quite affordable.
Hi Rhapsody,You have always been VERY helpful regarding your networking work especially over in the networking thread.
I AGREEE 1000% about the LPS's for switches having a dramatic effect on the SQ. a f Without looking back at who posted when they removed the M12 switch or re-inserted it, I would venture that they did not have the JCAT LPS connected with the M12 switch.
As I noted a few pages back I removed my M12's, but I use the JCAT LPSs with these switches. Two M12s/two LPSs. When I first used the M12 I thought it made a slight positive difference. When I added the LPS to the M12 it made a dramatic difference.
So, when the noted M12 user added the M12 recently and didn't like it, again, my guess is he did not have the M12 LPS connected as well.
I keep saying this but every system is different. Every users' room is different. Everyone's ears and sonic priorities are different.
I listen with a few astute/experienced listeners and we listen to the exact same thing at the exact same time and have totally different impressions and conclusions regarding what we are hearing.
Point being, be careful what you read from one poster and his ears/room/system regarding his conclusions most likely they don't pertain to what you are experiencing in your environment. Know what you hear and what you like, it's all that matters.
Sure I understand there are generalities, like the recent OS upgrade or the Taiko usb card/drivers etc, but the networking stuff imho can be tilted one way or another depending on a user's overall environment and full equation.
Jeez, who else does this??? Oh yeah....Lampizator!We can offer you a 100% refund of your EVO purchasing price should you wish to upgrade to the Extreme platform.
David, excellent question and I wondered the same. The answer is both, but I don't understand why. I asked Alex Crespi at Uptone and he replied with a comment that we all know to be true which is...everything matters. It may not be an answer I find fully satisfying but I can't refute the results.Marty, are you hearing the same difference with both local files and streamed music?
I use an LPS with my cable modem and the uptick is quite noticeable with bothDavid, excellent question and I wondered the same. The answer is both, but I don't understand why. I asked Alex Crespi at Uptone and he replied with a comment that we all know to be true which is...everything matters. It may not be an answer I find fully satisfying but I can't refute the results.
I believe Emile favors SMPS as long as they switch at a very high frequency, etc etc etc.
I will let @Taiko Audio clarify or negate my statement since I am not 100% sure.
why spend significant resources on your network now when Emile's NIC, switch, and router are due by year's end and will likely make all of these tweaks obsolete? With Emile's track record thus far, who of us would bet against Emile at this point? As Steve has suggested, what makes the most sense is to stay put until May.
This is the first explanation I've heard that makes sense with regard to why the "no network" option now can sound worse than constantly feeding the Extreme with ethernet. Thanks for sharing that. The new OS update really is a game changer.My previous neutral point of reference was to disconnect from the network but as Emile explains it, if you disconnect from the network, Windows then is forever searching for the network and this incessant pinging for something that is no longer there creates its own noise. Previously, this noise was buried in the Extreme's noise floor but with the noise floor now dramatically reduced, this noise is now exposed and is audible. It's the same thing with your router, intermediary switches, and cables, it seems you can now more readily appreciate the contribution or "flavoring" that each component offers. Since every network requires at the very least a router and intermediary cabling, it makes sense that this simplest configuration should now be the Extreme's starting point of reference.
Totally agree, CheersI’m a non-Extreme user, but love to follow this thread with all the wonderful developments and discoveries. I’m a major Taiko fan…just that I’m travelling an alternate road that Im not yet entirely ready to abandon.
For the past 3.5 years I have been developing a digitally-based system for local and remote streaming.
I discovered fairly early on that reducing RFI and EMI, jitter and phase noise, internal and external vibration that excites resonances and power supply noise and impedance along the entire network really has a major impact on sound quality. I also discovered that to gain maximum SQ benefits, the network components need to have the correct specs based on their position within the chain. The specs should always go from good to better as you progress down the chain. I also learned that components meant to enhance the stream, don’t always work as intended, depending on the environment they‘re in and the quality of the stream they’re treating. I have had several instances where extremely well reviewed components haven’t improved but rather downgraded sound quality. This was true in my case when treating the USB output of my server and with certain modules like ‘switches’ and cables on the input. In my system, I am aiming to deliver the very cleanest and most precise data stream to the server. In my experience, the more you reduce the above listed interferences, the better the stream and resulting SQ gets, but it’s important no to introduce anything that affects (as in reduces) transparency and neutrality. The other major element I have found to impact sound quality is network traffic. The greater the network activity and the busier the network is with superfluous activity (non-audio related), the worse the sound becomes. I have also found that a network requires a well thought through and designed screening strategy that excludes bi-directional radiation and provides zero continuity to carry pesky correlated and non-correlated currents. I use a common star arrangement to a low impedance ground for all cable screens including network.
Finally, the more I have optimized my system in terms of the above interference parameters, the better the sound quality has become, which implies that it produces cleaner, more precise sound waves to interact with my hearing and brain to produce a more precise, pure, dramatic, realistic, natural, emotional, message-laden conscious picture of music being performed by instruments and musicians in real spaces that sonically don‘t resemble my room. The better my system has become, the greater the impact of removing yet more of the interferences i.e the bigger and more impactful the improvements and the more profound disturbances like running-in or warming up after complete cool down have become.
One of my early discoveries was that power supplies used on the network are really responsible for a lot of the characteristics and presentation of the resulting music. Characteristics like purity, detail, pace, rhythm and timing, space, air, emotional involvement will all change for the better when power supplies are improved. My network uses some pretty cheap components….the modem, the router and the wi-fi-ethernet bridge are all consumer grade network products costing a couple of hundred pounds at most. The DC cables I use to deliver DC to these components sometimes cost 4-5x the price of the component itself and the power supply may be 20 times the price and in every case, I would rate the investment as being entirely worthwhile and perfectly in line with or even superior to the price/performance ratio of other hi-fi related upgrades. Running a $100 component with a $3000+ LPS seems to be entirely logical given the degree to which the LPS contributes to the final sound.
So in summary, as the Extreme gets better and better, as SW and interfaces improve, as noise floors are reduced, certain components in your network stream may very well begin to contribute or exert a negative influence. I would just say that such an experience is a result of the component itself or its power supply and should not be generalised into an engineering principal. I don‘t believe and find it counter-intuitive that delivering a cleaner, lower noise, more precise stream will ever sound inferior to a noisier, less precise version….however HOW you clean and resynthesize your stream becomes ever more important as the noise reaching the final detector (your ears) is reduced and your detectors are able to hear deeper into and resolve more of the character of the music. The message I believe is that you need to become more discerning in how your network is structured and the stream refined.
Question for @Taiko, will the planned switch/network card/ router come with their own Taiko LPSs or will that be left up to the user to pick?
