Does it affect SQ if the Extreme is shut down overnight rather than rebooted?We do suggest rebooting the Extreme weekly, but your experience of after 5 days is nice datapoint
Overnight shutdowns are not harmful, a good idea when there are power outages. It does take a while for the Extreme to come back on song, I have heard reports of about 30 minutes.Does it affect SQ if the Extreme is shut down overnight rather than rebooted?
I am guessing there is a memory leak that will be fixed for the final release, which is why I find more frequent restarts are necessary than once a week.We do suggest rebooting the Extreme weekly, but your experience of after 5 days is nice datapoint
I recall Emile had said never to shutdown the Extreme, and that it will take a lot longer than 30 min to “recover” after a shutdown, especially one as long as overnight. All the caps will drain, and it will take a few days to get back to normal stable performance. I think after a reboot, it’s about 30 min to get back to normal.Overnight shutdowns are not harmful, a good idea when there are power outages. It does take a while for the Extreme to come back on song, I have heard reports of about 30 minutes.
Christiaan has a lot of experience on start up and reboot SQ behaviour
If you are shutting down with the power switch on the back of the Extreme, then you are looking at at least 5 days before the caps are ready.I recall Emile had said never to shutdown the Extreme, and that it will take a lot longer than 30 min to “recover” after a shutdown, especially one as long as overnight. All the caps will drain, and it will take a few days to get back to normal stable performance. I think after a reboot, it’s about 30 min to get back to normal.
I have a quick question....I have XDMS Alpha 2.0
can someone tell me what XDMS Alpha 2.1 brings to the table
Yes. Ed just reached out and told me the same. SQ he says is the same as 2.0Besides some behind-the-scene code cleanup:
1 - DoP
2 - Can save favorites to Qobuz and Tidal
3 - Playlists UI somewhat functional
Nothing major
Is 2.1 in TestFlight? I have 0.0.1(5).Yes. Ed just reached out and told me the same. SQ he says is the same as 2.0
I'm finding something a little different, I'm having to have to restart my services for XDMS after 5 or 6 songs have played. The player seems to stop playing until I restart the two services in task manager.We do suggest rebooting the Extreme weekly, but your experience of after 5 days is nice datapoint
Also, now able to delete individual items from the Play Queue.Besides some behind-the-scene code cleanup:
1 - DoP
Nothing major
Most Alpha testers will want to use the most recent XDMS-release.Why would all of the Alpha testers not want to go to 2.1???
We're not aware of this being the case. EDIT: there may actually indeed be a Roon memory leak.I am guessing there is a memory leak that will be fixed for the final release, which is why I find more frequent restarts are necessary than once a week.
A regular restart should not be required as standard but it can help in certain situations. Personally, I don't restart the Extreme unless I have to due to investigations or upgrades. A restart is best done via the front panel button. Do not switch off the server on the back or disconnect the power cable as that will lead to a longer recovery period.Great! Is 2.1 on TestFlight? I don’t think I see it.
Does anyone else find that a restart of the Extreme is required every few days to bring SQ back to normal? It could be in my head, but there’s some loss of “magic” and exuberance when it’s been running for a 5-6 days without a restart.
That is correct. Unless there are underlying issues, the server normally performs best if it always remains on. The "up to 30 minutes" that Ed quoted stem from my experiences and are indeed referring to a soft restart. In this case, the power supply remains charged and therefore the effect is small and relatively short.I recall Emile had said never to shutdown the Extreme, and that it will take a lot longer than 30 min to “recover” after a shutdown, especially one as long as overnight. All the caps will drain, and it will take a few days to get back to normal stable performance. I think after a reboot, it’s about 30 min to get back to normal.
Yes, the front panel button shuts down the OS and puts the motherboard in a low-power state but the server's main power supply remains on.Rebooting means front button off and on again?
