Do you mean that if we have a two rail LPS then that itself will be a 17-18% improvement hence skipping the need for the distributor?
Or do you mean the distributor will still give 17-18% improvement in the case of a two rail LPS?
Will still give.
I am assuming that the DC Power Distributor will also come in either chrome or black finish as there was no where on the order form to ask color desired
Can you say anything about the gain with the wall wart feeding the power distributor?
It depends on the LPS. The Power Distributor can deliver a maximum of 10 Amps, so the LPS with which you power it must give at least that amperage. My little Super 3 Farad couldn't, my Paul Hynes puts out 12 Amps at 12 volts so it looks like it would be adequate.why don't you use the LPS that is powering your switch as it will then power the switch and router per Emile's schematic
Oh, okay.
However I suppose that the fact that the Paul Hynes can deliver a maximum of 12 Amp (you say between 0 and 10) does not preclude its use. It's right?
Will the router and distributor both come with grounding posts, like the switch?
Will DC cables be supplied?
From a practicality perspective, am wondering about stacking the switch, router, distributor on one shelf of my rack - how much of a bad idea is this?We’re looking into it, not very keen on making those ourselves.
You mean stack vertically right? I’m thinking the same… my rack is small.From a practicality perspective, am wondering about stacking the switch, router, distributor on one shelf of my rack - how much of a bad idea is this?
Yes, exactly.You mean stack vertically right? I’m thinking the same… my rack is small.
Will there be a limit for voltage in? Or any voltage in is okay?
And I assume voltage out will exactly be the same as voltage in, not modifiable, correct?
Will there be room for streaming radio in XDMS beta b?
Is there a possibility a dc distribution box could power the Extreme along with accoutrements in the future?
Ok, dc distributor supplying the juice for Taiko switch and Taiko router.
Would you recommend running the non-Taiko dirty side router on the Taiko dc distributor as well?
