Yes, I know where to find the product page. I was asking in the context of the first batch of 100 being sold out and the 2nd batch not being available until autumn, and was assuming that each batch is not a mix of chrome and black.
Ah yes, I did not mention that but I am using the standard supplied Wall-Wart at this point.@christian--maybe i missed this, but what are you using to power the switch in these experiments?
I have not tried the switch with the other servers. While it's possible, the Extreme Switch is really intended to work in tandem with the Extreme Network Card (inside the Extreme server).Hi Christian,
I saw that you have other servers beside Extreme. Did you try out the switch with other servers? Did the switch provide any improvements to other server?
A few of us did this a few months ago when the switches first arrived. At that time the consensus was that we could hear a difference. The connection to the Extreme using the port next to the power port was preferred.To all those who have the Taiko Switch and the NIC card, I would like to propose a little game; change the connector of the DAC cable that is in the Switch and connect it in the NIC and vice versa. Do you notice any change?
Bob, I think Francisco is talking about swapping the DAC cable end-for-end rather than trying both switch ports. Checking directionality of the DAC cable rather than finding a preference for switch port.A few of us did this a few months ago when the switches first arrived. At that time the consensus was that we could hear a difference. The connection to the Extreme using the port next to the power port was preferred.
ooopps. Thx. Sorry Francisco. Senior moment!Bob, I think Francisco is talking about swapping the DAC cable end-for-end rather than trying both switch ports. Checking directionality of the DAC cable rather than finding a preference for switch port.
Steve Z
It's a bitch isn't it Bob. They seem to be commonplace as we ageooopps. Thx. Sorry Francisco. Senior moment!
Some observations:a little game
Here’s what I do I save the entire album into a new playlist and I name the playlist the title of the albumHopefully simple XDMS question:
Is there a way to save streamed Albums (not playlists of tracks) into XDMS?
This is the way i’ve navigated my music listening through Roon for years. Very simple link, just save an album to “Albums” under “My Music”.
I see the link for saving tracks into playlists. And I see the link for saving all the tracks of an Album into a playlists.
But I’m looking to save the (streamed) Album (identified by cover pic and name) and organized by artist or Composer in one comprehensive list. (as in Roon).
Let me know if this is better a question for Dischord. Thanks
Much simpler than my method, Steve though you must have a Playlist list a mile long!Here’s what I do I save the entire album into a new playlist and I name the playlist the title of the album
This is great finding but the problem is you are talikng about QSFP-DD that is totally differentSome observations:
AWG
It seems the first available longer length cable (4m or 5m) with decreased AWG, for example from AWG 30 to AWG 24, should benefit (or not) the most from the increased wire diameter (4m vs. 7m for example).
Shorter lengths with the same AWG should among other things have different attenuation and interference, audible or not.
Max. Power Consumption
The discussed and tested DAC cable has a spec for Max. Power Consumption @ 0.1W. This a single cable maybe a non- twisted pair stranded cable as far as I understand from the FS.com provided specs.
The possibly compatible and much more expensive, short (1.5m max.), bi-cabled and faster 400G and 800G passive DAC cables are designed with ''ultra-low loss materials, square rings (!) , twisted pair cable 8 or 16 high-speed copper pairs (28 AWG) and max. Power Consumption @ 0.005W ''. With these features they provide ''power-efficient connectivity'' (for high speeds that is). But, do they sound different?
Obviously the SQ benefit of the Taiko selected DAC cable based on specs only has nothing to do with speed, but possibly reduced attenuation & - interference, length, AWG and max. power consumption could make a difference (if interchangeable with the original DAC) ?
Doesn’t that make a list of every track on every album? I have hundreds of saved Streamed Albums.That would be way too cumbersome for me to deal with.Here’s what I do I save the entire album into a new playlist and I name the playlist the title of the album
That’s my way until there is a better one. I rarely use this methodDoesn’t that make a list of every track on every album? I have hundreds of saved Streamed Albums.That would be way too cumbersome for me to deal with.
I would just like to be able to save streamed albums (whether they are called favorites or whatever) so they are cataloged in one place and easy to access and play.@wil what are you trying to save, just the album names? Are these just your Tidal or qobuz favorites?
