I love when Emile drops in to restore order among us!When you toggle the switch it’s effective from the next track you play. Stop track, toggle, play again accomplishes the same thing.
Indeed. Rebooting/restarting a server is generally a rare occurrence reserved for substantial changes to an application or operating system. Stopping/starting services is usually the way applications make changes to core functions/patches/updates without the need to reboot/restart the entire server. Stopping & starting services is generally programmatically achieved so an end user is oblivious.I think there’s confusion between “restart in xdms on remote”, “reboot Extreme,” simply stop and restart the stream and “stop and start xdms in Task Manager.
so the question becomes what is necessary to affect the toggle for default/alternative sound profile? I expect all that is needed (considering it is a toggle) is to stop playing, make the change, and restart playing. [edit: as confirmed by Emile@Taiko, above, post #202]
That said, it is alpha level software so backend functions may not be coded yet and require some additional manual efforts.
How do each of those adaptive setting differ from each other? What are they actually? Are these the "USB1, USB 2, USB 3, USB 4" profiles with individual icons on the Extreme desktop, or are these X0, 1, 2, 3 settings something different?XDMS Control App version 2.3.10 DAC settings has X0,1,2 and 3 selection working correctly, so no need to edit by hand anymore
Thank you, Emile. I'm glad to have the definitive answer.When you toggle the switch it’s effective from the next track you play. Stop track, toggle, play again accomplishes the same thing.
Maybe that was in a previous version of XDMS server/control app?? Now it clearly works by just stopping the music, toggling and replaying. The difference is quite audible between default and alternaopa
This is the way it is supposed to work, but being a bit of a Belt, Braces and Suspenders kind of person, I suggested to Steve to restart XDMS to be absolutely sureWhen you toggle the switch it’s effective from the next track you play. Stop track, toggle, play again accomplishes the same thing.
With 18 speculative posts appearing on three pages of this thread it's obvious that audiophiles have no patience whatsoever.
Steve Z
I second your opinion. Default is more natural, layered and airier. Alternative is more in-your-face and two-dimensional, reminding me somewhat of the difference between the latest Roon upgrade (a kind of "whitish" or "blanched" feel to the sound) and classic XDMS (more natural and airier; even before NSM). The difference is subtle though.I have tried alternative and I clearly prefer default. More 3d and layered.
I also had the latest server update related to Qobuz SQ installed recently and i can also confirm that Qobuz now sounds to my ears smoother and more analogue than before . The streaming sound quality is on par with SSD playback in my system. My preference even before doing the upgrade has been Alternative profile as it sounds more transparent to my ears. As per Ed it does less pre processing than default and as the noise floor in our systems becomes lower, preference of people tends to swing to alternative.I am reading that many members are raving about the recent backend update for Qobuz SQ. I did get an uptick but not to the same degree as others. I felt there was more clarity and better defined deep bass but I am in "alternative". I was just curious if those finding a bigger improvement inSQ are in "default"or in "alternative"
I have to admit that just like @Rhapsody i’ve spent the past 2 days listening to both default as well as alternative in Sound Profile. I have to agree that there is merit in your post and yes it is a close call. I do agree that with many files and in “ alternative” there is just too much and as a result the sound stage is pushed forward and does indeed sound 2D.This isn’t with all songs but is noticeable when heard. This also seems to vary in degree depending on what is being played. I do find a slightly set back presentation with a bit more air in default but after almost 2 days it is close. However in many of the songs that I use as demo the issue is mote of an in your face presentation. Plus I listen nearfield. The good news is there is no right answer but rather comes down to system dependence and personal preference The interesting caveat is that I have gone back to default as I’m rather enjoying it. I’m saving alternative for several files that do well with it.I second your opinion. Default is more natural, layered and airier. Alternative is more in-your-face and two-dimensional, reminding me somewhat of the difference between the latest Roon upgrade (a kind of "whitish" or "blanched" feel to the sound) and classic XDMS (more natural and airier; even before NSM). The difference is subtle though.
Yes, system or personal preference dependent. I did not mean to suggest that Default is 3D and Alternative is 2D. The difference is (very) subtle between the two modes, but a more apt description would be like applying normal lens setting (Default) and applying zoom setting (Alternative) in photography, the latter bringing the sound forward a bit, but at the expense of losing a bit of depth or layering structure.Totally system dependent. Every time someone comments about the SP setting I go and check it, back and forth, back and forth. In the system that I am checking it on, with the speakers 10' out in the room I get a full 3D holographic soundstage with either setting. If you are not getting a 3D, layered soundstage with one of the settings then there is a strange interaction going on with your system with the setting that is giving you 2D sound, which is very possible.
In this system that I am going back and forth on I get a sense more air and space "feeling" with alternative but when I switch to Defualt I could easily leave it there as I definitely don't have 2D Sound. I don't know how many systems that I have, but I don't have 2D sound on any of them. If I did there is something wrong somewhere other than the Sound Profile setting.
My comments relate to my system/room etc, nothing to do with other people's systems. Also personal preference is involved as well.
I do not think that one can generalize and say that one setting has global sonic results. Again, totally system dependent imho.
That is exactly how I would describe it. Yet like Bob says it is so close that I will likely use both depending on the file I play.Yes, system or personal preference dependent. I did not mean to suggest that Default is 3D and Alternative is 2D. The difference is (very) subtle between the two modes, but a more apt description would be like applying normal lens setting (Default) and applying zoom setting (Alternative) in photography, the latter bringing the sound forward a bit, but at the expense of losing a bit of depth or layering structure.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
