Thanks, Bob.
It's a fantastic review.... I also noted that in the review Ken thinks that it's 20% underpriced at 75,000 Pounds (US$116,000) in the UK!
You are going to have to find a good restaurant for me to take you to when I come up to hear this rig!So I am convinced that the performance of the TechDas can be dramatically improved by disabling the air suspension then using and Active isolation table as opposed to the current passive solution. There is a strong possibility I can do this test for myself in the not too distant future.....![]()
Christian, does this mean you are willing to take the isolation platform to Massachusetts to Bob Graham's place and try it under his TechDas? If so, you will only be about an hour from me. You are most welcome to stop by and hear my system and try the platform under my SME. More likely I suspect, though, is that there is a TechDas closer to you.
I'm still building up my intestinal fortitude to put in an order. I need a few more days. If the Table Stable is not a good match for it, I can still use it under my other turntable and or RTR machine. Thanks for the offer to visit.
We need to have an NVS vs. AF-1 shootout!
Christian,
i applaud your pursuit of ultimate performance. and as you know, i'm a fan of the Herzan Stable Table isolation.
OTOH i'm skeptical that the Herzan will 'improve' the Tech Das, which as been voiced for the air legs isolation. it will more likely sound different, not necessarily better. of course; you will never know unless you try it, and typically i'm the one pushing manufacturers to try any possible way to improve their 'already sorted out' systems.
a product like a Tech Das has a holistic all together design.
good luck with your temptation. i hope you try it.
That's a report I would like to hear, since I have thought of getting a Vibraplane for my SME 30. Wouldn't want it to be a long run for a short slide, though, since the SME is pretty well suspended and my floor is concrete slab which theoretically takes care of some of the directional components.
Christian,
Here is an image of my preloaded Vibraplane under my SME 30/12. Note that the motor controller is isolated. The steel ballast plate plus the weight of the turntable is close to the Vibraplane maximum design load of 275 lbs. The increased isolation improved the performance pretty significantly. The TechDas and Rockport also incorporate air isolation suspensions. The active isolation of the Herzan Stable Table would probably improve the SME even further, though at a premium price. My floor is suspended wood, though I do have two lolli columns under in the basement directly under the front legs of the rack. There is no detectible movement of the rack or floor.
As Miles stated the shoot has been down by M.F.Bring it on!
Technically hasn't Fremer done each vs. the Continuum?
Bring it on!
can someone share what the conclusions were
Paskinn and friends did compare a 2000 Rockport, Continuum, TechDas and SME 30/12 all in the same system. Comments are in another WBF TechDas thread.
