What's the internal impedance of the Master Signature? This isn't one of the parameters I've seen written on the inside of the box. I'm also curious about SUT matching. Thanks.
Be careful, the azimuth changes somewhat when you remove/reinsertThanks Tima. My settings are:
VTF: 1.5g
Loading: 500 ohms
AS: 0.5g
My Master Signature hit 100 hours last night, so I may start to experiment with lowering the VTF by 0.05-0.1g
Another observation: I don't know if it has to do with stylus profile or not, but I notice that my stylus seems cleaner than on my other cartridges and that I do not need to clean it as often. That is a good thing as the exposed cantilever really makes me nervous in the rear arm location as cleaning it is awkward. I can simply remove the headshell which I may now do every few days or so. What are other people's cleaning habits with this cartridge?
I ran across the following at: https://www.artisanfidelity.com/phonocartridges/van-den-hul-colibri-master-stradivarius-signature
They are a vdH dealer. More spec on the MstrSig than I've seen elsewhere. I think the effective mass range is what is typical as I've seen this vary by instance and custom support for 'arms with higher EFM
Van Den Hul Colibri MASTER Stradivarius Signature
Body Materials - Stradivarius lacquered KOA, Polycarbonate and African Blackwood bodies optional.
Cantilever Material - Boron
Diamond Stylus - VDH profile, extended long life
Output voltage: (Low) 0.5 mV and (High) 1.1 mV
Recommended vertical tracking force: 1.35g - 1.5 g
Recommended effective tonearm mass: 10g - 16 g
Optimal loading: 50 ohms - 600 ohms
Internal coil impedance: 13 ohms
Anti-Skating force 0.3g - 0.5g
Weight - 7g - 8g est.
Correct - mine has 0.9mV output and has 36 ohm impedance - I believe the normal 1.1mV output carts are 39 ohms.The 13 ohms is incorrect, I believe. @mountainjoe tracked down the info so he could have a proper SUT built and determined it to be in the mid 30s as I recall.
the headshell.
I got the same 13 ohm response from the US distributor but it's hard to believe that can be correct - especially in light of the high output of this cartridge. I then asked the person I bought it from ( who is on this forum) - who lives in Europe - and he got the answer I gave in my reply (I believe from his dealer).You're welcome for trying to help you.
I saw the other post but don't know what is correct. At least the above is published by a dealer. This is a van den Hul problem - normally the maker is open to publishing such information and we would not have guesswork like now. Same for compliance. Probably because every cartridge is a one-off.
I was also frustrated by the lack of a clear spec from VdH but from a technical perspective, it seems much more likely that the higher value is the correct one.
Was that US distributor Randy?
Not sure - I got the information through Christopher Thornton at Artisan Fidelity who said he got it from the US distributor.
Yeah, my bad for the previous hasty reply on the go. Your help is definitely appreciated!You're welcome for trying to help you.
Then that would be Finest Fidelity.
When you say 30/39 ohms more likely because of higher output, could you pls say a bit more on that? I'm not questioning you, just trying to learn.
In the case of an MC cart, there is a fixed magnet instead of a primary and so the # of turns in the coil will determine how much voltage is generated at the output leads (for a given amount of magnetic flux). In order to generate a high output like 1.1mV, that implies either the magnetic flux is very high (the Master Sig does appear to have a very strong magnet as I discovered with my issue running this cart on my Artisan Fidelity TT) - or that there are lots of windings, or both.
Given the very fine gauge of wire used on these carts, they will typically have a high resistance so you expect that the higher the output voltage of the cart, the higher the number of windings in the coil, and consequently a relatively high impedance compared to lower output carts.
Perhaps VdH is doing something I don't understand but basing things on other MC designs, it seems unlikely that they could achieve such a high output and very low impedance (13 ohms) at the same time - even with such a strong magnet.
Yes the high output 1,1mV VdH MS has around 39 ohm.
I do have 2 of them. One is 39.3 ohm and the other 39.7 ohm.
I do have a mid output 0,75mV VdH MS which has 23.2 ohm.
And my newest low output , 0,38mV VdH MS which has 12.2 ohm.
