Congrats, Caelin, that sure is a beautiful turntable!
Nice system too. What power cords are you using?
Very cool and congratulations ! Curious how a log cabin room sounds? I suspect the walls really help with difraction
Maggie's are great speakers...hard to beat for the $$'s
Caelin, what is your phono amp? That table is amazing looking, what others did you consider in your quest for 'the final turntable' (as opposed to 'the latest turntable')?
I have an AMG v12. Do you suggest Alpha or Sigma digital for turntable power supplies? (Or depends on the ps itself?)
That is a simple and elegant arm design. It looks like the opposite of something like the TriPlanar arm which is fully adjustable but very complicated. It looks as though the arm base is fixed on the plinth and the headshell has no slots, so how is overhang adjusted? And is there an anti skate mechanism or VTA adjustment?
Looks to move just like a unipivot. My concern is that it looks like dirt can get into the bearing pretty easily. Although it would be pretty easy to remove and clean. I assume there is some lubricant in the bearing cup? One advantage over the normal unipivot design is there is no sharp point to damage. I wonder how the friction compares to a unipivot with a sharp bearing?
I do not see an antiskate device in the picture, and can not tell if there is a VTA adjustment either. Does not look like it though. No VTA adjustment and no overhang adjustment is a deal breaker for me.
Had a chance to hear this arm and the Kronos TT at RMAF 2013. The sound was not bad, but not great either. This was show conditions and really does not mean much. Wish I could hear it in better circumstances.
Self proclamations about sound quality are not usually very meaningful without personal knowledge of the person and their system. So I won't say other than I am very happy with the performance. Steve, Marty and Russ will be coming to the northwest for a visit. Let's see what they have to say about the performance. Or, since you are located in the Seattle area you could come on over and hear it for yourself.
