Can't wait to audition one at Ben Lau's showroom!I will try to take more time to share my experience, about the cable and about the rest, you are right.
This cable uses very large sections of conductors (both for low electrical resistance and for high weight / low vibrations). It uses pure copper.
It also uses a large thickness of mechanical damping, again to avoid microphonics effects, and you can really hear that.
This damping, based on cotton, is completely hand made. Any length can be done but each added meter adds as much extra hand work.
The diameter is large but it is still extremely flexible, so very easy to use and not fragile at all.
Chaining many cables still work at 192KHz, showing that one cable will work at 192KHz with a lot of margin (which is clearly not the case with some high cost AES-EBU cables).
About the sound, I found too many AES-EBU cables having air in the sound, or having body and good bass, but very few have both. This is what I wanted, grip, articulation, cobtrol, weight in bass and 3D air and no-metallic treble, with good timbre in classical music. The adjustments were done with the Totaldac d150-anniversary speakers and the Magico M6 mostly.
This sounds excellent
Can you please record it lauder.
It is very low volume.
It also could be little longer than 19 seconds.
And this is the reason why anyone running Windows or Linux should set the music app / engine of their choice's priority to "Realtime". There is a noticeable uptick in quality.A new Totaldac d1-streamer software is available for Roon users (and later for UPNP and Airplay).
Here is a review about it by Michael Lavorgna:
"totaldac Streamer Update: What A Difference A RTOS Can Make"
totaldac Streamer Update: What A Difference A RTOS Can Make - Twittering Machines
Michael Lavorgna's Twittering Machines: HiFi with a twisttwitteringmachines.com
Agree 100%.I consider the D1 Direct one of the best value on the market today. For those more conservative with investments, this is one that will be held on for a very long time if not the final purchase.
Even if it is an initial stretch to purchase, I know I would have saved money longterm not cycling through four or more units before settling on Totaldac.
Price to performance, this is the unit I would consider.
The new software is for the d1-streamer and for the streamer board option for DAC, but not for a DAC alone.Dear all, what would be the better Choice: A used Totaldac D1 Six with newest Software Or a new d1 tube mk2?
Ok i got that point, but any conclusions which Dac Would be the better choice, if there is a opportunity for a d1 six for at a lower price point as a new d1 tube mk2?The new software is for the d1-streamer and for the streamer board option for DAC, but not for a DAC alone.
The answer depends on your system and possibly also on your taste because the d1-six has a class A transistor output stage and the d1-tube-mk2 has a triode output stage.Ok i got that point, but any conclusions which Dac Would be the better choice, if there is a opportunity for a d1 six for at a lower price point as a new d1 tube mk2?
I use a Aurender N100H as Server/Streamer and a acousticplan Aruna 300B as amplifier. Living Voice Speakers. i prefer to be on the warmer emotional side. But the Aruna brings very much of this to the table, so the Dac could maybe be more on Resolution and Soundstage, if he do Not kill the emotions. thanks for sharing your ideas.The answer depends on your system and possibly also on your taste because the d1-six has a class A transistor output stage and the d1-tube-mk2 has a triode output stage.
Also the d1-six has RCA and balanced output whereas the d1-tube-mk2 has unbalanced outputs only.
What is the rest of your system composed of? You can also answer privately by e-mail if you prefer so.
So single ended output is fine.I use a Aurender N100H as Server/Streamer and a acousticplan Aruna 300B as amplifier. Living Voice Speakers. i prefer to be on the warmer emotional side. But the Aruna brings very much of this to the table, so the Dac could maybe be more on Resolution and Soundstage, if he do Not kill the emotions. thanks for sharing your ideas.
