How did you hear about that wonderful contraption Marc ?Btw Bill, just about to order the Roadrunner tacho.
How did you hear about that wonderful contraption Marc ?I just checked our PM’s, we talked about the Roadrunner first time in 2017, it’s about time you get one !
There was one for sale on Audiogon, with a Falcon power supply, i suggested we go 50/50 as i already had the Roadrunner. I realized i needed the Eagle not the Falcon and we did not buy it. They where impossible to get back then. I just realized that was when i first started talking with Marc, big mistakeThis is funny you went back and checked when he first mentioned it
Bill, what kind of toque and consumption does the motor/controller you put together for SOTA have ? Will i drive a 100lb platter on an air bearing ?
https://sotaturntables.com/product-category/eclipse-series/
"What's Best PMs"We have one PM thread going that is 150 pages long, that coronavirus did make some strange bedfellows![]()
Thank you Bill !The BLDC motors have 2-3x the torque of their AC synch equivalents, so it should be OK. Also, the motor starts the platter at ~5 RPM and ramps up to 33/45/78 so the torque requirement is much less than a motor that spins up to speed instantly.
Oh Tim, one always considers alternatives. This is high end audio. But I so love my sound off lp, that I'm really not motivated.
Tim,
What do you consider a minimum specification for "accuracy" in a turntable?
Sorry but I can't understand why anyone should consider another turntable before discussing a few numbers ...![]()
Tim, I don't have any info to give. The new speed controller is in the early days, and the engineer is being a little cagey. I know he's predicting way better than the 0.3% my current unit is specced at.
But as my current designer said, all the options they tried that used a feedback loop to lock better than 0.3% killed the bass and made the sound greyer.
Phoenix, I believe the latter phenomenon may be the case in my situation. I'm playing albums w some strobe-indicated drift or shimmer, and then corrected, and struggling to hear any difference. Below my audible threshold it seems. However, put a musician in my seat with absolute sensitivity to pitch variation, and satisfaction may drop.
Has it arrived, Marc?Throw in eccentrically pressed discs...ie off centre spindle holes...
Great comment, btw.
I'll see where my new Roadrunner sits re 33.33 and 33.31.
In order to pick up sound accurately from the analog disc, the rotation of the platter must be rotated at a constant speed without any “fluctuation”. In general, accurate rotation is obtained by servo control by negative feedback, but at the micro level, if it rotates or becomes faster, it detects it and slows it, and repeats the operation to make it faster if it gets slower. Although this level and cycle are determined by the gain of the control system and the loop speed, the period of the speed control of the platter which is the mechanical system surely comes into the audio band. In general, accurate rotation is obtained by servo control by negative feedback, but at the micro level, if it rotates or becomes faster, it detects it and slows it, and repeats the operation to make it faster if it gets slower. If you try to measure a period with a small level, you can not measure the instantaneous state, so you measure the average value. Therefore, fine vibration generated by servo control can not be measured by the measuring instrument, it depends on the human ear.
