Hi Joeling,Hi Vincent,
Does the volume control on the D1-dual affect the resolution or cause any detrimental impact to the sound ? Thanks
Hi Vincent,Hi Joeling,
There is no very simple answer. You need a volume control somewhere and all have their characteritics, and an active preamp have also the pros and cons of the active gain.
I can at least tell you than I am using the DAC volume control for my publics demoes and for my personal use, that's the best way I found and I tuned the rest of the system accordingly.
you can not, I agonized over this because I didn't want to ship it all the way to France. You would have to remove an entire circuit board which sits over another circuit board to access two of them. You have two choices, send to france have him do it and over charge you, or just rest them under the dac and call it a day. They do change the sound, whether it's a positive to you is up to your ears.I am looking to see if anyone has added the upgraded footers to their Dacs or Streamers? Can you install them yourself and whats the Thread count? I have a D1 Streamer and D1 Direct Dac with stock feet.
they are made by Revopod, easy to get them in the US. Totaldac needs a dealer or distribution here in the US to tackle simple things like this. To have to send my dac overseas for feet is ridiculous, and Vincent is constantly upgrading and monetizing every little upgrade he can under the sun. It's a control and money thing IMO, if you ask me the US market isn't a major area of focus for him. Excellent dac otherwise.Thanks for the reply, I found the footers they use and would prefer to save a few dollars and time so looks like I will forgo them for now.
Don
