By very early next year, one will be able to control all CH functions by a free Android app. I have seen the alpha version in action and it looked like a finished product to me already.Yes, that is if you're using the c1 pre and configure it to use the CH remote then yes. The CH remote is a small heavy gorgeous remote with a magnet to attach to the side /case of the C1. Despite this, i don't use it as i'm running through a nagra jazz pre. It has 5 buttons, two for volume and two for scan forward and backward.
Two new reviews of the Trinity dac and Trinity phono can be found on the Trinity website. Look for the post 'reviews'. Both reviews are glowing.
What are the connections marked with an arrow above?
And what are the dimensions (size) of the DAC?
Thanks.
Hmm. I just noticed the blank port on my Trinity DAC where on the photo of your unit there is a port for grounding. Why would this just be on the version for Hong Kong? We have our Tripoints in the US! It has been difficult given the case construction to ground to the case (the screws are way too small).
The left-most port next to Trinity logo in the photo is empty.
For the Trinity DAC sold in Hong Kong, it is a port for connection to groundboxes such as Tripoint or Entreq.
Doing so improves the sonic performance significantly.
This photo was taken when I was testing a Totaldac usb cable with the Trinity DAC last month.
Great photo. I ground my Zanden digital and agree it makes a big difference...in fact I ground 3 out of the 4 Zanden boxes by chassis....and also 'ground signal' by the RCA digital out of the DAC itself.
