This photo was taken when I was testing a Totaldac usb cable with the Trinity DAC last month.
How did you like the TotalDAC D1 USB cable with the Trinity ?
Maybe because Audioexotics, the HK Trinity dealer is also the Tripoint official dealer.
BTW there is a similar groundbox port on the Trinity Media PC!
And there are two such ground ports on the trinity phono. For both AC ground and DC ground.
Yes, I see them on my Trinity Phono. Was wondering which one (AC or DC) to use to go to the Tripoint.
I have to say, that Totaldac USB cable is just stunning. I have two highly regarded USB cables at home, each costing roughly twice as much as this one (both in $1000 range), and the Totaldac cable is clearly superior.
Totaldac cable sounds more natural, with more body and weight to the sound, with much better rendering of the images as 3D objects floating in space. Other cables sound flat and bright in comparision.
I have to say, that I'm tempted to open up the box on the cable. AFAIK it uses some kind of active filter, that basicly firewalls the computer from the computer noise. It certailny sounds like one. Highly recommended !
The Trinity media pc and Trinity dac remain the best cd-combo I have heard so far by a wide margin. However, in the beginning of next year I will give a new, that is not yet launched, dsd dac a serious listen. This mystery dac will be able to play inter alia dsd 128 and dsd 256. This gives me the opportunity to listen to some dsd recordings such as Channel Classics recordings in their native format. So far I am extremely happy with the pcm files played trough the Trinity combo, so it is not my intention at all to get rid of this Trinity combo. Far from it, I will remain a very happy Trinity owner for many years to come. But I am curious to find out how good dsd really is. For now I will leave you guessing about this new mystery dac.
I disagree. CH Precision C1 with X1 power supply sounded faster and more like real music when I demo'd it against Trinity. The Trinity was sweet sounding but had no impact
and weight in comparison. CH also sounded better on lower volumes. Just my opinion and a matter of taste....
Hi Audiocrack,
Yes, your Trinity Media PC + DAC combo must be wonderful!
Do you want to improve their performance further?
In Hong Kong, Trinity Media PC owners are using Pranawire Linebacker Extreme with it for power-conditioning.
The Media PC inevitably gives out emf noise into the powerline. The Linebacker Extreme improves the performance of the MediaPC/the whole system significantly. Very expensive but most users think that the money is well spent.
I auditioned two of such systems and totally agree that Linebacker Extreme is a worthwhile upgrade path for Trinity PC+DAC combo.
Trinity media PC is simply a PC with Windows operating systems in a customised case running customised software. It is quite expensive. I thought it has well thought power supply. If it gives out so much noise and needs an expensive conditioner to function best, why don't one build a low noise PC like CAPs running much wider choice of software like JRiver or JPlay. It is much cheaper.
I have been demoed the Trinity PC before. The interface is laughable and half cooked. Just want to say there is a simply better way to connect to Trinity DAC.
Hi Audiocrack,
Please explain what is 'laughable' and 'half cooked' about the interface of Trinity.
Do not really want to start an argument with you. You are the one who cannot stand any negative comments on any Trinity products. Just do investigation on JRiver, LMS, Lumin, Aurrender or future Devialet server to understand proper interface.
To you, the interface is perfect. To me, it is laughable. There is freedom of speech. I do not need to explain to you.
