Dear DaveyF: +++++ " you believe that ALL a'philes ( including myself) who like tube gear are NOT able to hear the distortions that are according to you.......... the continued exposure to tube gear has sullied my ability (and for that matter all those who listen to tube gear) to discern inherent distortions in said tube gear........... anyone who doesn't hear what you hear in tube gear and NOT in ss gear is inherently technically ignorant....... " +++++
Perhaps the more " elusive " audio subject is about distortions, first because normally " no one " speaks about distortions " no one " likes to speaks about what's right or wrong but what " I like it ". Normally we have not in deep experiences on non-obvious audio system distortions ( any kind. ) me either.
Sometime ago ( years. ) I decide to start an " adventure/explore " on distortions: learn about distortions but not only learn in technical way that could help for nothing really but learn how different kind of distortions sounds and how detect ( be aware of it ) it. This was a really hard task because I could not find out nothing that could help me on that " adventure ". So, I started to walk in my own " designed "road " with out real knowledge on the " road path ". It was not only a learning lesson but even that I falled " once and again " was full of " fun ".
Certainly it's a long road to " home " and I can't give the overall leartning proccess. What I can tell you is that to be aware of distoritons you need to know how it sounds and if not then you never be able to detect it. I'm trained by my self to be aware of those distortions not only on electronics but on speakers, cartridges, tonearms and the like.
( non obvious ones ) that you can't do it and not because my ears are better than nyou but because I'm traied to do it and you not only are not trained but are not aware of its existense even that you are hearing/heard it every day.
So you can't understand part of my posts because you are unaware of what I'm talking about.
I posted that we have to have a self designed method/proccess to evaluate audio items, part of that method/proccess is about distortions.
There are tests that are " easy " to experienced where we can be aware of IMD, for example, in speakers. How?, well any passive two ways ( and 3-way an even up. ) speakers has " high " IMD through its two drivers and especial in the " woofer ". Normally a two ways speaker crossover is around 2.5-3.5 khz with a low bass frequency around 40 hz to 55 hz. This means that the woofer frequency range is wider than " ideal " and it's handling from 40 hz to 3.5 khz, problem is that this woofer has to reproduce at the same time all the notes/harmonics in that wide frequency range and ( for example ) when the recording ask for a 50 hz " sound " and at the same time a 2.5 khz one exist an IMD level that's very high because the woofer excursions need it for that 50 hz notes and that can't stopped faster enough to avoid distortions that affect the reproduction of a 3.5 khz notes. I'm not very good to explain it but more or less is what happen there. Same for a threee ways speaker but on different frequency range.
If we integrate a pair of active subwoofers in true stereo fashion to that two-three way passive speakers audio system we can detect immediatly the dramatic quality performance improvement.
Why? because now we have a wider frequency range in the bass management ?, NO, it's because we lower the IMD distortions level in the main speakers woofers that now are avoiding those long woofer excursions that now are handled by the subs. A good crossover frequency could be 80hz, this liberate the small main speaker woofers of those " low " frequency range and those frequencies that before were performed by the main speakers now are handled by an active dedicated speaker ( name it: subwoofers. ) designed in specific for handle precisely and accuartely that kind of frequency range. Of course we have additional benefits/improvements with that subs integration as: better bass management, not only deepest but accurate, neutral, defined, with low bass distortions an almost no compromise system: these are side improvements over that lower audio system IMD.
Like this example there are many that I learned and where I have first and experiences. DaveyF, believe me that I know what I'm talking about and in this regards you don't because you have not the pertinent training yet and that's all.
I hope this could help to understand my posts in better way.
Regards and enjoy the music,
R.
