And take home some "work"Wow. I’m going to check out our labs and see what they’re using to isolate their microscopes.
(,...) They said turntable is rotating machine which creates a lot of vibrations from unbalanced platter, spindle bearing and drive motor. Active isolation platform will continuously fight to cancel this vibration and it will not succeed since it is intrinsic. This causes disturbing oscillation which is detrimental to the sound. In this regard, turntable with rigid mounting is more susceptible to oscillation, as no platter is completely dynamic balanced and there is no suspension to buffer the vibration. (...)
David, i'll only comment that my comment is not in any way a criticism of the AS-2000. there are good reasons for a separate plinth and motor box in a string drive design. it isolates the motor from the plinth. it's a valid approach.That's actually untrue Mike. Going in I knew very well that the Herzan is a bad idea for any turntable, I explained discussed the reasons why in several threads here, long before the AS2000. Christian already had a negative data point with his AF1 and a Herzan, exactly the same outcome as with AS2000. Another invalid data point?
What the heck is "self noise" anyway? You haven't even seen an AS2000 how did you evaluate did come up with this evaluation?
david
I like this question.Can we know what toneram you will be using with the AF0?
I'm following this thread with interest. There seems to be a lot of talk about "self-noise" that's theoretical, not empirical. I've found that a very useful way to assess whether there's any noise that can be pernicious, regardless of source, is the simple use of a stethoscope. Folks, we're spending 10K and up for a cartridge and sometimes even more for cables! Surely anybody who calls themselves an audiophile can spend 50 bucks to buy a stethoscope on Ebay. Listen to your turntable base or shelf with the motor on or off and you'll know right away if you have noise generated by the gear of interest. You may not hear noise that's -150dB, but you'll not have any difficulty hearing noise that has more likely will an audible effect (<-60dB easily, probably even up to -90dB in some instances). But be careful what you wish for! Don't be surprised if you hear noise from your hallowed turntable base from your refrigerator compressor in the next room, or from your air conditioning unit. This is such a simple test that there's really no excuse for not performing it. Once you hear noise, you can then take any number of approaches to ameliorate it. I've found that mass (1" stainless steel plates) combined with constrained layer damping (neoprene, thin O-rings, other?) on study shelving is quite effective in many instances, and quite inexpensive compared to 10K+ active devices. My point is, a stethoscope provides real concrete evidence of noise that can be effectively documented. You can always remedy what you think is a genuine noise issue by throwing a lot of money at a solution (of which there are many), but doesn't it make far more sense to document it empirically first so you can then document its effective removal in an objective manner?
As far as stethoscopes, the common "old school" scopes have 2 heads (actually 2 surfaces- one each side of a single head; flat or a concave shallow bowl) that is sensitive to higher and lower frequencies respectively. The newer electronic stethoscopes (~$200) are remarkable and often contain dsp software for filtering or tuning of certain frequencies, Some even provide graphic output mapping to a smart phone so you can actually see what you are hearing!
If I do remember correctly, the TechDAS Custom Rack for AF1P is anI got the TechDas custom rack with the AF1p, but otherwise would love to try an active table under it.
Artesania Exoteric Rack with a customized Krion platform on top.
The Accurion i4L active table has nearly the same size, than the standard Glass- or Krion turntable Top Platform.
As I said this is an very interesting topic, everyone can have his own opinion. ddk and Nishikawa san are not big fans of active isolation. I discussed with Nishikawa san during the development phase of AF0 whether he would include active isolation in the design, He said no for the reasons I have listed before.As I often say, something can be true or false depending on the frequencies being addressed. I can assure you active tables can cancel intrinsic vibrations - for example they cancel the intrinsic vibrations induced by the scanning and focusing mechanical systems in atomic force microscopes where we do not address micro-vibrations but nano-vibrations. The rotational speed of a turntable is around half an hertz, well bellow the range of action of the the active suspension, but probably the motor generates other frequencies.
IMHO there are too many uncontrolled particular conditions that can affect the performance of isolation devices and we can't have firm rules on their application. I got the TechDas custom rack with the AF1p, but otherwise would love to try an active table under it.
Spot on, in my opinion. I have been using a stethoscope to tune my turntable for over a decade. And I also don’t know either where this <<"non-linear" and "high resonant modes">> is coming from. Noise, by definition, is always unwanted signal; though admittedly the proper removal of it can sometimes be very challenging.Francisco and Ron,
I'll respectfully have to agree to disagree. In my view, any noise you can hear with a stethoscope = bad. No noise= good. To say some noise is good or that it needs to be there so it can "drain" properly is like saying, well, second order harmonic distortion from tubes is a good thing because it makes music sound better. Distortion is distortion and noise is noise IMHO.
I'll also have to respectfully disagree that "most" stethoscopes are "non-linear" and have "high resonant modes". (Where is that coming from?) It is true that the flat and concave surfaces have specific and limited bandwidth tuning intentionally since they are designed to auscultate specific contractile and blood flow turbulence events and anomalies like pulsations, murmurs, valve sounds and bruits. Fortunately, as an ophthalmologist, I didn't have to use them for cardiac evaluation (except for carotid bruits) since in general, I always sucked at it because I always found the typical hospital environment too damn noisy to make anything other than crude assessments! However, I've found that a stethoscope has given me very useful information for turntable suspensions as well as general gear isolation for over 40 years in the quietude of my room, but of course, YMMV.
Francisco and Ron,
Just google "stethoscope" "frequency response". Hundreds of measurements available on the net. And they usually show good quality stethoscopes from known brands, not the $20 stethoscopes.Spot on, in my opinion. I have been using a stethoscope to tune my turntable for over a decade. And I also don’t know either where this <<"non-linear" and "high resonant modes">> is coming from. Noise, by definition, is always unwanted signal; though admittedly the proper removal of it can sometimes be very challenging.
Yeah "where is this coming from" does not literally mean what you wrote is false - rather, it is irrelevant, because we are not aiming to take accurate measurements with such a device, rather a rough close-up of mechanical noise seeping into the equipment, similar to a basic microscope. I don't think it's hard to understand the basic concept and fundamental issue.Just google "stethoscope" "frequency response". Hundreds of measurements available on the net. And they usually show good quality stethoscopes from known brands, not the $20 stethoscopes.
Stethoscopes are developed for specif frequency bands and weights to optimize their use in medical applications.
