Of course , However as to how much weight that opinion carries ?You can still have an opinion on the sound, no?
Yep! People comparing digital videos of different recordings recorded on unfamiliar systems in unfamiliar rooms and thinking they have an understanding of the in-the-room sound of the systems is ludicrous to me.
Hard to judge anything unless you know the exact recording each used. Go listen to the different recordings yourself…a couple have very deep and heavy bass without much definition like Tim’s and some sound taugh and lighter where the tympanies can be more clearly heard. Some sound distant and recessed, some brash a bit harsh and in your face…etc.You can still have an opinion on the sound, no?
If we find ourselves agreeing with particular members more often than not, I guess we can trust their opinion more than those we disagree with on a regular basis.Of course , However as to how much weight that opinion carries ?
Good please share the version of Fanfare you used (please again if you did already so I don’t have to dig for it). THX!I encourage including the catalog number for each video reported although the reference target for me is not a YouTube video.
Yes I agree we can't determine whether the harsh sound of the trumpets/trombone at 2.02 in Stenhos vid, for example, is due to the version he's playing or the system.Hard to judge anything unless you know the exact recording each used. Go listen to the different recordings yourself…a couple have very deep and heavy bass without much definition like Tim’s and some sound taugh and lighter where the tympanies can be more clearly heard. Some sound distant and recessed, some brash a bit harsh and in your face…etc.
Yes I agree we can't determine whether the harsh sound of the trumpets/trombone at 2.02 in Stenhos vid, for example, are due to the version he's playing or the system.
Doesn't stop us making a judgement as to what sounds best to us though.
It would be nice to know the details on the recordings whenever anyone posts.
Thx! These three on streaming has the heaviest bass drum and weight in the low end
View attachment 132620View attachment 132621View attachment 132622Other recordings were lighter in lower regions…some for the better , some for the worse (some sounded kind of harsh).
Presumably, Stehno posts his videos for comparison because he thinks they represent the sound he hears in his room and he wants to share that with us to support his point of view.
Not really…you kind of hear they are there but not really in their own space. I can tell you later ones I found that had much clearer timpani but at the expense of some weight and power. Some of those did a good job of not sounding overtly thin though…some just sounded thin…I also have the second entry (Oue/Minnesota) and will take a listen to that one. With the timpani, bass drum and tam-tam at double-forte and forte, it is a challenging piece of music.
edit: does any one of these offer the timpani as holding their own against the bass drum, such that you can hear the two notes of the timpani with some clarity?
Sure but it doesn’t tell anything meaningful about what the systems are doing right or wrongYes I agree we can't determine whether the harsh sound of the trumpets/trombone at 2.02 in Stenhos vid, for example, is due to the version he's playing or the system.
Fwiw, the Tim video sounds more natural and musically engaging to me. Yes, the bass could use more definition but I don't hear it detracting from the musical message. Maybe it's the room that's causing some bass bloat or maybe it's in the recording. But I don't hear any objectionable resonances or room colorations.
The Stehno video has nice taught bass, but the Cymbal crashes and the horns sometimes sound harsh. Harshness in a recording always breaks the spell for me.
The label says Telarc Digital so this is a digital recording and all versions would be from the same analog to digital process. Question is, was the original recording harsh and needed to be tweaked to sound good, probably.
I have to agree with your assessment – at least in part.
The video I shared in my prior post (no. 1) is the same digital interpretation but digital version of what Tim played. Tim’s was from Telarc and mine from Reference Recordings but same live performance.
The bass was the point of that post otherwise I would not have posted that less-than-desireable engineered recording. I like to think or hope the brunt of harshness is from the recording perhaps from an inferior analog-to-digital conversion? And I suspect the less-than-stellar engineering negatively influenced Tim's video also to some extent.
I have at least 3 or 4 interpretations of this same piece and I wasn’t sure which one matched Tim’s video so that night I recorded the 3 I quickly found.
Anyway, videos no. 2 and 3 seem easily more musical and better engineered than the first video. IMO, no. 3 is the best engineered.
Actually, Peter, i think my videos are reasonably representative of the in-room presentation. Reasonably being the keyword here. After all, I'm using a tiny $150 stereo mic that plugs directly into my iPhone and I'm sure I'm bumping up against some of its limitations at times. Not to mention my own recording engineering limitations.Presumably, Stehno posts his videos for comparison because he thinks they represent the sound he hears in his room and he wants to share that with us to support his point of view.
