Mitchco, welcome to the forum. That is an exceptionally well done article indeed. Certainly goes beyond the call of duty there
One question though. I saw how you used your Lynx card to capture the sine wave but now how you captured the FLAC and WAV files. Did you just compare them as they sat on disk, or did you play and then capture them as with the function generator signal.
Thanks and welcome again.
Hey Amir, thanks. Yes, this is a basic null test using the files on disk...
I see there is further discussion that maybe during or after the the digital to analog conversion and analog line output stage, there is some thing causing a waveform difference between FLAC and WAV. The manufacturer of my card has these specs while installed in the computer:
ANALOG IN PERFORMANCE
(24-BIT MODE WITH CARD INSTALLED IN COMPUTER)
Frequency 20 Hz - 20 kHz, +0/-0.1 dB
Response at 44.1 kHz sample rate
Dynamic Range 117 dB, A-weighted
Signal-to-Noise 116 dB, A-weighted
Channel Crosstalk -120 dB maximum, 1 kHz signal, -1 dBFS
THD + N -108 dB (0.0004%) @ -1 DBFS
-104 dB (0.0006%) @ -8 DBFS
1 kHz signal, 22 Hz - 22 kHz BW
ANALOG OUT PERFORMANCE
Signal-to-Noise 117 dB, A-weighted
Channel Crosstalk -120 dB max., 1 kHz signal, -1 dBFS
THD + N -97 dB (0.0014%) @ -1 DBFS
Plus since we know what ADC and DAC are being used, we can look up the jitter, etc.
But, given the specs, I am wondering what else could be measured to somehow quantify the differences some people hear? Do you have a proposal?
Cheers,
Mitch
