Sorry- I don't see what you're referring to. None of your bullet points appear relevant. What am I missing?
great group you have there; can't go wrong. i'm sure many will have different favorites.Short list is looking like...
CS Port
Grand Prix Parabolica
TW Acustic Raven
VPI HW40
AMG Viella 12 with Turbo arm
Kuzma Stabi M or R with 4P
Looking also at Bergmann and Brinkmann...a friend has the Galder and it's really good.
Rega Planar 10, SME 30, Roksan Xerxes 20 Plus, Rockport Tech, Walker Audio (despite no longer being made), custom turntables by Scienceofsightsound of Princeton, NJ (state of the art really), Micro Seiki , Vertere TT (have been a long time fan of Turaj Mogadham's designs). Also, Clearaudio TT are awesome!Short list is looking like...
CS Port
TW Acustic Raven
VPI HW40
CS Port
TW Acustic Raven
VPI HW40
Could be that's an important factor. Because I don't listen to classical at all and I don't find any of the characteristics you describe like dark, laid back, lacking energy......Dark too. And I auditioned exclusively on classical with different arms and carts
When Technics set out to do the SL1200G they apparently did a from-the-ground-up redesign. A customer of ours wanted to send one to us to see what we could do with it so I took it apart and did an inspection. This is one of those places where an enourmous R&D budget (Technics is Panasonic after all...) really pays off. The machine has little in common with their older SL1200s except appearance. For example, its one of the most speed-stable turntables made at any price.
Get a Sutherland Timeline and you'll see what I mean. You can play an LP all day with that machine and the dots will stay firmly in place on the wall. Most machines made for high end audio can't do that.
In addition the new SL1200 uses 5 different methods of vibration/damping control. It has a rigid and non-resonant plinth- which is what you want for the platter bearing and the tonearm mount to prevent vibration from creating colorations.
Its weaknesses are the tonearm (which is vastly improved over the stock arm of years ago) and the platter pad. But its easy enough to mount a different arm on the 'table, and we've done it a number of times, using the Triplanar, which is a state of the art arm.
Ok, we agre it does not hurt. But the fact that the point can stay static forever has no correlation with sound quality. Such point only shows how subjective and unreliable can be our comments on value in the high-end. MHO, but consider the point you refer as a kind of Veblen feeling - people feel confidence in this type of misleading and abusive information, if it is accurate it should sound good. BTW, I also consider that the current Technics are top turntables - I could happily live with an SP10 R with an SME or Graham.
We recently had an interesting debate on this subject, thanks. It started here https://www.whatsbestforum.com/threads/natural-sound.32867/post-744076
IMHO feedback in turntables has no relation with feedback in amplifiers, although some controllers of turntables that have no feedback use feedback in the wave generators and drivers. Confusing?
Now you are addressing how a manufacturer prices his line of products - it is a complex and interesting subject, but we would need real data to comment on it. But It would be great if you or someone else pointed a link to this Vladimir Lamm statement.
A typical high end manufacturer does not have the structure and capability to produce such turntable, his costs would be artificial, what is the point of such comparison?
I am not in bikes and IMHO such analogies only manage to spread noise and confusion. I appreciate debating the high-end with proper facts, without analogies.
Feedback: … belt driven turntables have a feedback system in the form of a rotating platter suspended in a belt …
1. YesQuestions:
1. the speed stability is constant during play so the motor control compensates for stylus drag, etc?
2. looking at the design, how do you accommodate mounting a Tri-Planar or other tonearm? You must have to install/create an armboard specific to that arm's length.
3. what length arms can be mounted?
4. replace the platter pad with?
I'll take that as a red herring then.Nothing I'd care go further off topic to make apparent.
And many of them employ feedback (servo control) to keep the motor speed constant. That is how my Sota Cosmos worked.Feedback: … belt driven turntables have a feedback system in the form of a rotating platter suspended in a belt …
You don't need to be into bikes to understand the underlying principle.
Veblen good - Wikipedia
en.wikipedia.org
The reason of such a comparison is simple. Technics set an intention and followed thru with it. Because they wanted to, because its made in greater numbers; it really doesn't matter so much as the simple fact that their SL1200G (ignoring the arm) outperforms turntables that cost quite a bit more. Enough so that people owning those machines might feel like rationalizing why they spent the money.
Yes, it is why I asked for a direct link. A nice thing about Lamm is that their site is filled with a lot of relevant information, but finding something specific can take some time . Anyway I will try to search it.IIRC Vladimir said that in an interview. He's got a lot of them on his site.
What generation of Oracle mat? I had a few types and liked them, but most were self adherent to the platter - once put in service they become the best, no possible comparison!(...) 4. I like the Oracle mat. Its not too hard, not too soft; the patter pad has to be the same hardness as the LP for best effect. It has to be permanently mounted to the platter so you can't use the platter mounting hardware.
