Greetings Re-tread,Greetings @Geert1962,
When available, would you be able to clarify and provide a little more information on the following two facets:
1. I believe you are suggesting you are employing the Shunyata Omega Ethernet cable, correct?
2. If #1 above is “yes”, can you provide a little more detail about the sonic uplift your received versus the your previous ethernet cable?
I have an Omega Ethernet cable on order, and I am interested to learn about others’ experiences.
Thank you kindly,
Re-tread
This is my first post on WBF. I’ve been a member for a little under a year and always just surfed the forums. I find myself in between gigs and have a bit more time right now so I figured I’d try to step up, participate and pay it forward wherever I can.Hello,
I would like to share my (limited) experience with upgrading my ethernet cable.
For the last 2 1/2 years I used Audioquest Vodka and before that Cinnamon.
Two weeks ago I bought Audioquest Diamond.
I have two audio systems.
In the main system the difference in sound quality is not small. More of everything!
The most striking aspects are, 3d sounstage which is bigger and especially far more nuanced. More finesse. In complex music different instruments or voices are better and easier to follow separately while at the same time making the music as a whole more natural and realistic!
I was really holding back the potential of this system, I discovered.
The above is true for my main system.
I also tried it with my more modest system in which I use Qobuz on my laptop feeding Antelope Zodiac Platinum which converts the signal from digital USB to digital coax. followed by NAD M2 amplifier / dac. Here I can also here an improvement, but it's rather small and it's difficult to describe.
Yesterday, at the request of my father, we tried the Diamond in his system (which consists of Purepower 1050 power regenerator, NAD M50 streamer, NAD M51 dac, Onda Ligera IPA 006 integrated amp and Dali Grand speakers. The conclusion being that he needs one also.
Thank you for sharing. I’ve been curious to try the Furutech LAN 8 NCF, so the ferrite risks you brought up give me that last little push I needed. The Furutech cables aren’t that expensive so if they’re not better, not a big loss.![]()
Can I put Ferrite Cores on my ethernet cables to reduce noise and crosstalk? Why I don't see any fitted ferrite cores on LAN cables sold ...
Answer (1 of 9): Of course you can. BUT. That would increase EMC noise and also crosstalk… And it would most likely increase the bit error rate so much that the risk of that cable could not be used any more. IF you really need to lower the EMC radiation from your Ethernet cables (even if I se...www.quora.com
These guys have some interesting comments on ethernet cables.
You won't regret it. Great cable! I have two, used on A and B side of an EtherRegen.Furutech LAN 8 NCF
Wow, that is quite a variety of cablesI got a Pink Faun and also ordered both FTA metis and crystal connect Monet, let you know the comparison once i can test them, Pink Faun is a very good one which fall into the analog side and doesn't sound too analytical, i sold my Dalby meda and keep the pink Faun, acoustic revive quadrant and TWL freedom now, its quite interesting to mix and match the cables between modem router switches and streamer to give you different taste
Thanks, keep me posted.I got a Pink Faun and also ordered both FTA metis and crystal connect Monet, let you know the comparison once i can test them, Pink Faun is a very good one which fall into the analog side and doesn't sound too analytical, i sold my Dalby meda and keep the pink Faun, acoustic revive quadrant and TWL freedom now, its quite interesting to mix and match the cables between modem router switches and streamer to give you different taste
I use the Pink Faun cables too - preferred them over Shunyata OmegaI got a Pink Faun and also ordered both FTA metis and crystal connect Monet, let you know the comparison once i can test them, Pink Faun is a very good one which fall into the analog side and doesn't sound too analytical, i sold my Dalby meda and keep the pink Faun, acoustic revive quadrant and TWL freedom now, its quite interesting to mix and match the cables between modem router switches and streamer to give you different taste
