I tried a number of cables finally settling in on Shunyata Sigma’s. Amazing cables. A couple of months ago I moved up to the Shunyata Omega’s’, OMG, they blow every other cable I have ever heard away.
i too have an X1 with fiber optic going into the X1 from a Cisco switch. Query if the quality of my 20+ foot Ethernet cable makes a difference since only the short fiber optic cable is going into the DAC?For now i am using NordostHeimdall ethernet cable , have tried Audioquest cinnamon and vodka , as i just got an Lumin X1 streamer i am going to try out a Sotm switch with sfp later this year. But i also think that the Shunyata ethernet cables sounds really interesting.
Do you guys know about Paul Pang Platinum-M Lan cable ?
I've been told it's amazing.View attachment 52191
And mine is as quiet as a church mouse.Quite easily. The underlying issue is about ground plane noise being passed along the shielding between the two metal plug shells. I float the shielding at both ends to prevent this.
You can keep the shield and metal connectors. As long as both devices the cable connects are grounded, to the same ground point, there will be no current flow in the shield.Quite easily. The underlying issue is about ground plane noise being passed along the shielding between the two metal plug shells. I float the shielding at both ends to prevent this.
Hi there,Hi all, what is the current consensus on shielded vs. unshielded ethernet cable?
@Taiko Audio says that unshielded twisted pair ethernet is superior to shielded sonically, while @Sablon Audio says unshielded ethernet cable do not have sufficient noise rejection and he quadruple shields his cables. How do we reconcile these diametrically opposing views from industry experts?
I use Esprit Eureka and have best of two options…Hi all, what is the current consensus on shielded vs. unshielded ethernet cable?
It's easy. You A/B them and choose the one you prefer. Why would you go with someone else's opinion?Hi all, what is the current consensus on shielded vs. unshielded ethernet cable?
I think it’s important to consider context. Emile was speaking in terms of the Extreme, which has been highly optimized in terms of both hardware and software. What one observes with an Extreme might not carry over to other servers. There have been a couple of switches, for example, that have been found to be detrimental with the Extreme but are highly favored with other servers. So if you have an Extreme equipped with the USB card and are running TAS, then you might find your preferences align with Emile’s. If you don’t then maybe opposing views might be more applicable.Hi all, what is the current consensus on shielded vs. unshielded ethernet cable?
On the first third of the cable, there is no shielding. On the next third, there is one layer of shielding and on the last third, two layers of shielding. The result is a true combination of the qualities of shielded and unshielded cables in terms of silence, bandwidth, dynamics and details.”
