Hi
Poking at a favorite hornet nest here... If you pull the tail of a tiger ....
The questions should be more precise about what kind of measurments are we referring to. Earl gEddes has demonstrated that we tolerate a level of THD that is far higher than what was previously thought .. THD of the order of 10% for example is deemed quite acceptable by many, in the bass we tolerate and come to accept far more. So the question should truly be the correlation between what are we measuring and our preferences not "measurements" as a whole.
It is sooo easy and convenient to dismiss measurements. This has become a favorite past time here on the WBF. Question : Does anyone actually believe that those who design and manufacturer your <insert favorite manufacturer> components do not measure them so that they can at least repeat the performances? And once they have a good set of what they and/or like make sure that these components meet those requirements .. err.. measure well within the parameters they have found to correlate with those desiderata? Our hobby is based on technology. Without getting too philosophical here; a mixture of the scientific and pragmatism. There are things we know how to measure and many we don't, it isn't because they aren't measurable. However much we haul rocks against the works of Harman luminaries, they did come up with an indisputable fact: Preferred speakers (in this example) share some common measurable traits...err. measurements... We don't know it all but we know at least that. This is a good place to start ...
Speaker manufacturers do microphone measurements. For electronics that's not necessary or accurate. Aside from THD, the measurements going into electronics are more to make sure the unit is perfectly stable and problem free. The topology could be win or lose when it's hooked up to speakers however. You can have two amps that on paper have the same measurements as far as you can tell, but subjectively one might be a total flop.
<snip>
If you're buying a $50k amplifier do you really want it to be based on simple measurements a monkey can accomplish, or would you prefer that it was designed by someone that is intimate with every part in it and was able to make a cohesive unit with knowledge that can't be had at the average electronics school but rather earned by truly caring about what it takes to accomplish high end sound?
I don't try to judge sound quality by eye, but my subjective experience, for many years, has been the opposite of yours. More often than not, I prefer the sound of equipment that measures well over "thicker bass" and "warmer amplifiers." This goes all the way back to when I was 19 or 20 and traded the Altec Valencias and Kenwood integrated amp for a pair of large Advents and a Harmon Kardon. It continued to the adoption of digital and then ripping all my discs to a server. To my ears, every step has been an improvement. To others it would be the march to sterility. Different strokes.
Tim
Phelonious, Got ya. But Bryston, for example, has great measurements and has great bass, while Sanders amp is an exercise in engineering and has lean bass. Ditto for Magico and YG... As an experienced marketing professional, let me throw out this thought at you: people like having the luxury of good sound in their life. At the same time, there is an unquenchable demand among consumers for good information to make solid decisions when spending their hard earned $$$$. Yet in this hobby, people are in the dark. Useful information is hard to come by. Most (not all!!!) reviewers are disgusting and just act as marketing departments for manufacturers and have created a Fukc the Audio Fan culture because they get very expensive audio gear as free loans, or buy at a great discount so they can later resell.
Audio fans are dying to get closer the knowledge of the experience with an audio product and everyone would love to know the true value of an audio product. After all, if you want a laptop, it's so easy to check the size, weight, cpu, memory, software, etc. , regardless if it says Dell, HP, Lenovo, or whatever. But the problem is that audio is an experience good, which can't be evaluated like that. So here come these companies and position themselves as "designing based on science" (as if everyone is not!). So people in a market segment for whom science-based decision making is an important criteria can then have a piece of mind and write a big check.
Yet, checking a typical measurements section in Stereophile, they publish 6 figures: impedance/ phase vs. frequency, spectral decay, crossover response, lateral response, vertical response, etc. From a quick novice glance, the measurements don't look very different from a "dirt cheap" speaker to one that costs as much as a house. (An acquaintance of mine has 7 children and actually lives in a home that costs less than a Magico q7 part 2.)
So can someone please explain to me, as clearly and patiently as you would explain to your doting grandfather, what these 6 stereophile measurements mean and whether they shed light on the what the speaker will sound like? And are there any other important measurements that Stereophile may be missing?
IME ... nope !!!.... just throwing this out there ....
The greatest loss in realism between the live performance and listening to the stereo in your living room ....
.... is the RECORDING
IME ... nope !!!
I have a killer "bad" recording, Ike and Tina Turner, back in the good ol' days, some tracks recorded on a cheap tape unit in a club setting - on a normal system the glare and hotness of these recordings would drive a man insane,. I picked it up in op shop for a dollar, the previous owner obviously couldn't take it ...
But, an amazing transformation takes place when the system is in good enough shape - all screechiness falls away, and you're truly aware of Tina just powering on the vocals, and all the subtleties of the backing musicians' efforts fall into place - it has become like listening to a live performance, and one gets the full emotional charge from the experience ... these are the reasons I find it worthwhile pulling out all the stops on occasion, to get the best sound.
I used to adhere religiously to my odometer for my bicycle and my heart rate monitor. Now I don't own either. I can do it by "ear."
Making it work better!Sorry fAs but I couldnt disagree more. A bad recording sounds bad on the best system. If you have a "screechy" recording as you put it, Ill interpret that as bright, what are you doing to your system to stop it from sounding bright?
