Well years ago when I wrote the Tice PB review, I received a note from a gentleman in the UK who had hard wired his system ino the wall. The upshot was a significant jump in SQ but caveat emptor. Not to mention, no electrician would do it.
Is this "what's best forum" or "who's chicken forum"
Seriously, though, it seems to me that for the best evaluation of any power line products there should be a comparison to a hard-wired component; if a big selling point of high-end outlets and cords is the quality of the connection it only makes sense to see what things sound like without those connections at all.
Things like spas, saunas, air conditioners, etc are all frequently added to existing dwellings and hard-wired in. I know they have UL-approved internal connections for this, but some enterprising, informed and capable manufacturer or hobbyist should be able to figure out a good way to do that for a power amp (after all, some are as big as spas and saunas)
we did have a member here who hardwired his entire system. Claimed his system imaged perfectly from another room in the house and that he had a wonderful soundstage with his ear right up to the tweeter
And you'd still need a circuit breaker, right? Have we decided on how those contribute to the sound? I know we have fancy power conditioners, wire to connect the audiophile sockets to the breakers, fancy receptacles and face plates, and audio grade fuses, but are there audiophile breakers?Yeah, but usually when things are hardwired together they are in a junction box where two or more cable enter into a junction box with strain reliefs that hold the cables tight at the point they enter the junction box. And then the wires are twisted together and wire nuts are twisted over the wires that are twisted together (Chubby Checker anyone?). For the average audiophile, that would be a nightmare. You would have to solder the wires together and not just merely twist them together. And then we would have to argue about what type of solder to use and what temperature to melt the solder with using a calibrated soldering iron. And then we would have to argue about what type of material the junction box should be made of and the plate that would be used on the junction box and how we would push the wires through the faceplate into the junction box.
Yes, sir.And you'd still need a circuit breaker, right? Have we decided on how those contribute to the sound? I know we have fancy power conditioners, wire to connect the audiophile sockets to the breakers, fancy receptacles and face plates, and audio grade fuses, but are there audiophile breakers?
Frank was always good for comic relief.
Mark, I'm really talking about someone capable and knowledgable doing this specifically for evaluation of power line components. To my mind that's an area where comparative listening (at least, if not objective testing) could be easily improved.
If nothing really is very close to hard wiring, I would expect some high-end amplifier (and probably power conditioner and/or regenerator) manufacturers to build in a way to do this, as things like spas and saunas are.
It really wouldn't be hard to do, but it would take some modifications to your amp and wall outlet to do this safely. If premium power cords are really all they are cracked up to be, hard-wiring with common romex cable could make things sound worse.
Tom, that looks like complete product, panel, breakers, etc. And can you identify it for me?Yes, sir.
Tom
Gary, thank you.
Curious to know what (substitute) breakers Mike L. used in his E=T cabinet....
I don't think that you'll find consensusThere are even 2-3 hundred $ AC outlet covers. I think that I'd enjoy $300 of music more than $300 of AC outlets or outlet covers.
However, upgrading the AC outlets to ones that grip better would improve SQ. I used the Hubbell hospital outlets with the green dot - the ones with the unplated copper terminals. I think that there's someone on this forum who would recommend another version, but I don't remember the one that was specifically recommended.
