Hi Barry
no ,not at all.I very strongly believe in vibration control.I haven’t tried these CMS footers,but I also use a lot of different footers and know they can ,if you find the ones that fit your system ,can make a positive difference .
I got no problem with audio fuses in general and believe everything can make a difference.
1.I got a problem with anybody claiming,some quantum science ,but does not explain it In detail.I am a scientist and would love to learn more.
2.I got a problem if customers get ripped off.I believe every business should make money, but these margins are a bit far fetched.
If I had to design fuses,what would I do,No1 ,I would firstly make a fuse for the AC side and one for the DC side.Very different in design.
A.On the AC side ,use the best conductive material,like pure Graphene and make the ends of the fuse ,with small ribbs,to ensure excellent contact.Best possible vibration control inside the fuse and shield the fuse from any noise and noise pick up and electrical and magnetic interference
B.For the DC fuse would maybe not go for the least resistance as in the AC fuse,but build in some small resistance,now the fuse could work like a small choke,but would do my best to control any vibration and shield the fuse against any noise and noise pick up from any electrical and magnetic interference .A little bit more resistance,could make the sound bit more mellow and the small like choke could minimise some noise.
Again ,this is Theory,will it work,how knows,just some ideas .
If you are happy spending that kind of money,it’s ok with me,it’s your money,but I got a problem with false advertising and claims.
You are 100% correct,with your claim, I should listen to these fuses,if they were $100 ,I would purchase them ,but $2800 is a lot of money.
No bad feeling at all,it is just a hobby and we all know,it is full of strange claims and funny people.I am maybe the biggest clown and refuse to see the obvious,everything is always possible.
Let us enjoy music and find pleasure and peace.
Cheers,
