How do you get below -160 dB with a 16-bit DAC? That does not jive with my admittedly limited understanding of the math...
I tested that a few years ago in a series of blind tests I performed. I compared DVD-A players feeding a then state of the art Mark Levinson No 36S when playing CD versus the same title in DVD-A. In every case, the ML DAC improved on the on-board DAC but could not match the improved 24/96 Khz version of the same material. Compared to the internal DAC in the transport, the ML DAC closed half the gap but could not go all the way.^ Is now a bad time to ask about the effect different DACs/CDPs have on either 16/44 or 24/192 etc..., sound wise.? Would you rather have a $500 DAC playing 24/192 or a SOTA DAC playing 16/44?
Won't comment on the spaciousness of studio recordings but will say that there's nothing wrong with the dynamics in my view. Is the guitar as loud as the mandolin? Yes. Is that how it is in nature? No. But I don't think it's excessively compressed, I think it is mixed that way. Listen to the attack of those stringed instruments. It doesn't sound compressed to me. I could be wrong, though. Maybe someone who really knows compression can comment...Bruce?
Tim
As for DSD, I find our DSD ADCs get closer to the mic feed than our PCM converters. But that is a whole other discussion.
I did not follow this, sorry...
Noise decorrelation (dither) adds random noise to the signal, typically (not always) at the lsb level, and was originally added to help mask the correlated quantization noise floor and make it sound more "analog".
In my mind, the situation is opposite what you stated, so I must be off-base. D.c. is the opposite of dither since it is non-random by definition,
rounding has nothing to do with dither (again opposite since rounding correlates the lsbs better to the bit reduction)
and truncation adds distortion since lsb information is lost.
I suppose dither might help truncation errors by decorrelating them, that would make sense.
My models start ideal and then I add artifacts as required (dither, jitter, threshold errors, etc.) For the issue I was looking at in the other thread I did not want dither.
Definitely!!![]()
I'd take the one without the non-obvious fatal flaw. Think back about all the DACs you've owned... the annoying flaw that's different in each one and you don't figure out until you've lost the receipt ;-)
That is not how noise shaping is talked about or implemented. The two are distinct operations with one shaping the quantization noise and then dither neutralizing distortion. http://en.wikipedia.org/wiki/Noise_shaping
"Noise shaping is a technique typically used in digital audio, image, and video processing, usually in combination with dithering, as part of the process of quantization or bit-depth reduction of a digital signal. Its purpose is to increase the apparent signal to noise ratio of the resultant signal.
Noise shaping works by putting the quantization error in a feedback loop. Any feedback loop functions as a filter, so by creating a feedback loop for the error itself, the error can be filtered as desired. The simplest example would be:
Noise shaping must also always involve an appropriate amount of dither within the process itself so as to prevent determinable and correlated errors to the signal itself. If dither is not used then noise shaping effectively functions merely as distortion shaping — pushing the distortion energy around to different frequency bands, but it is still distortion. If dither is added to the process as:
So it is clear that the two concepts are distinct and spoken about as such.
Now if you mean dither with different probability distributions, then that is not the use of it by Bob or me in the context you quoted me.
A DC offset is unconditional and can easily be disqualified as being dither. Rounding is conditional and just may be random and uncorrelated enough to count as dither.
The biggest problem with most of the DACs I've bought is that I was comparing them to the best DACs I already had, which were already sonically transparent. Therfore, they couldn't make many real audible improvements.
The most egregious audible problems are almost always in the music that went into the ADC that started the journey through digital land. These days those are generally really good, and even if they weren't, audiophiles and mastering engineers can't do much about them but live with them!
Here's where I'm still confused. You're saying that comparing a direct microphone feed to an ADC - DAC cycle of that feed should show no audible difference, and yet that is generally untrue. Very small differences perhaps, but consistently noticeable differences nonetheless.
There's nothing to PM you about. The files sound the same to me, and for the ones that are different those differences are about 48 dB down. What are these files supposed to show, and how do they prove that bit depth affects more than the noise floor?
--Ethan
My results are the same. I was under the impression that the samples were about reconstruction filter pre/post echo. If they are, they prove my point because they don't show any artifacts as large as what the article their provider cited as being audible, not by a country mile!
When I do this level-matched, time-syched and DBT, my listeners score random guessing. Also true of a number of other experimenters. True for any audio source, including a live feed. True for many generations of re-recording, even with fairly humble converters.
I listen to live feeds from microphones for days at a time when I record band and choir festivals. My recordings sound nothing like what I hear from my recording desk which is typically just a few feet from the mics. That's true of the output of the mic preamps, and its true of the recordings I make. I know enough about mics and acoustics to understand why.
Well, obviously not transparent enough judging by your lack of hearing differences in the file I linked to. The majority of people who have listened to these files have identified them correctly in blind tests. I guess they must have more transparent systems than you or Ethan??
And yet, when others (apparently not of your acquaintance) do the test, or when mastering engineers are tested, no data storage system, digital or analog, is transparent to the mic preamp output??
I have never found ADCs and DACs to be 100% sonically transparent. There are always differences.
--Ethan
Same test as you did - downloaded unidentified files & no contact with me until a PM of results.Blind or double blind?
