There is nothing wrong with preferring LPs to CDs, that is simply a matter of taste.
OTOH CD has far fewer, maybe none if properly engineered, inaccuracies that LPs. As somebody who has been making recordings, both of music and data (and music is, strictly speaking air pressure fluctuation data) for about 50 years and worked in R&D in the record player business in the mid 1970s I have two bits of experience which I regard as 99% sure, which nobody without any recording experience could have knowledge of.
The first is that the euphonic colourations added by both the analogue recording process to tape and then the subsequent manipulation of the signal to make an LP playable and an LP side of acceptable length cuttable have all been known for over 40 years.
Anybody who has done music recordings and has had the opportunity to compare the off-tape sound to the direct microphone feed will know that there is a bigger difference on an analogue tape recorder than on any digital recorder, as long as levels are correctly set. To my ears it is possible to make a recording of the type of music I do where the off-tape (it isn't tape any more of course but the nomenclature sticks) is indistinguishable from the microphone feed.
That is not to say I don't like playing LPs, I have 4 record players, all sound different to each other and I like them all but play one of them most. I just don't think it is plausible that there is some magic as-yet-explained-by-man "superiority" explanation of why LPs sound nice when the known shortcomings explain the difference in sound between CD and LP perfectly well.
The CD will be much closer in sound to what the recording engineer produced, IME, but that doesn't stop the LP sounding nicer to somebody who either has a differently balanced system/room or just different taste in sound balance. Also there are far more ways to tune sound to taste with LPs since the components of a record player, particularly cartridges, can have big differences between them.
