Just had a thought: would anyone be aware of any experiment done where the same mic configuration was set up at different distances, say from an orchestra, going into the audience space, and the same single performance was captured in a single take from say, 3 to 4 such positions. The real point would be to have all those takes available to listen and compare to each other: would be fascinating to see how the differences in the "quality level" of the playback equipment and environment would then impact on people's reactions to the different versions ...
Frank
This experiment has been done many times over many years as the people who record professionally have, through shared knowledge and experience, developed the best techniques. I told you I knew some people who record live, in performance spaces, professionally, and I'd ask why recording from the middle of the hall doesn't sound good, while listening from there can be quite gratifying. This is the answer I got from the best of them:
2 reasons that are interrelated. Very briefly:
1. Mics record - people listen - different process.
2. As you move away from the source, the ratio between the source of the sound, and the space the sound is recorded in changes. The brain compensates, mics don't.
Many books on the subject.
Also look here for interesting info
http://www.dpamicrophones.com/en/Microp … tereo.aspx
Don't ask me how the brain compensates (an even better question might be why it
doesn't compensate when listening to the recording). As he says above, there are many books on the subject, I'm sure you can look into it if you're interested. But that's the part - the brain's compensation - that "doesn't make sense," Frank. The recording process? He made perfect sense of it above in a single sentence: "As you move away from the source, the ratio between the source of the sound, and the space the sound is recorded in changes."
Ambient mush. You don't hear it sitting in that seat. But recording from there is just bad technique.
So what can we conclude from all of this?
That microphones don't hear like ears do.
That recording equipment doesn't record like brains listen.
That the professionals who make the recordings we play on our systems understand this, even if we don't, and use microphones and recording equipment the way they work best and hopefully, sounds more natural, but it is not natural. The ratio between the sound and the space has been manipulated to create a facsimile of the real relationship between music and space; the recording
is the original event.
Or at least it's the closest thing we have.
Tim
