And in life like in anything & everything else, we should always take the time, and do things right.
--- Yup? :b
--- Yup? :b
Is there any reason to use subs in your system as it allready goes down to 5hz? I don't think adding subs would make any difference in your case.
Wendell
OOOPPPSSS, I read the graph wrong, it is 8 to 9 db up at approx 30 hz. It is 5db up at 20hz, I am still liking it though. Its gotta sound better than flat for listening to music. But not for accuracy.
Wendell
This one has fared well over time. It is from the older Synthesis SDEC 1000/2500 Installation Guide. View attachment 3879
Hi Bruce, your question, What is the actual room response? What are you refering to?
Hi Northstar, Which curve do you use, could you please post a graph of it and the response you have in room. I am looking for a response for music. Can I assume you are using REW also? Or do you use a different measuring program.
Thanks,
Wendell
It does indeed sound better. Why do you say it is not accurate? Ok, yes, as soon as we play content below reference level (whatever level at which is was mixed), the spectral balance is no longer accurate. Attempts have been made by Dolby and Audyssey to develop dynamic loudness compensation, which is theoretically the best way to address it. I have no idea if these work well, but thus far I have not found that to be the case in my inadequate explorations.OOOPPPSSS, I read the graph wrong, it is 8 to 9 db up at approx 30 hz. It is 5db up at 20hz, I am still liking it though. Its gotta sound better than flat for listening to music. But not for accuracy.
Wendell
I took a look and there were the only two places where flatness of response was mentioned as an ideal:Hi Roger, I am sure it has been said a number of times in this post that a "flat response is accurate". But that it is not something to emulate except for particular purposes such as a recording studio. I do not have a recording studio.
On one level, that means flattening out all the bumps and dips by careful placement of speakers, which is indeed a good thing. It does not necessarily mean there is no tilt or room gain compensation or whatever other shaping of the curve. However much, if any, of that would be present would be based on both the desired playback volume and spectrum that Bruce likes to hear when referencing other content on his system, as that is his "reference target" when mastering his own product, assuming it has to fit within that context.the ultimate goal is to have as flat of response as I can below 1k by just using good positioning techniques and speaker controls without having to resort to outboard digital or analog EQ.
Here he equates accurate with flat, but I have never seen anyone aim for a truly flat response in speakers as it elevates the treble too much. All the automatic EQ systems include a target curve that is not perfectly flat just for this reason, let alone the bass issues.Accurate playback of the source is usually the goal in a recording studio. In the home, it's been my experience that few people actually prefer a truly flat system
Nor I. The problem with language is that if you ask anyone who is interested in high fidelity sound if they want to listen to a system with a flat frequency response or one that is not, they most likely say they want the flat response. That could be because flat response in electronics is a good thing, so logic says why not the speakers, too. Or it could mean they want smooth, uniform response, as no one wants the usual forms of non-flat response, like lumpy bass, peaky treble, etc. Flat is surely better than all those horrors. What very few people realize is that what sounds flat and "accurate" is some form of gently departing curves away from that ruler flat line.A flat response does not sound like something that I want to listen to in my stereo room.
The Synthesis graph was the first time I'd encountered a target curve that reflected a bass rise to any degree (Anthem Room Correction has a small one), and my bass rise follows the same curve but keeps going before it levels off around 20 Hz. I wanted to see what was down there, but it is often a disappointment. Mic pops and other unwanted spuriae not heard so not removed. I have a switchable 20 Hz high pass filter in the system for such occasions.Roger, you mention that you use a curve, is the graph you posted the desired goal? Can you post a graph of your in room response?
Hey Bruce,
Nice frequency response! Would be interesting to see the ETC's and Waterfalls as well. Are you enjoying the sound?
I wrote an article comparing my untreated room, with acoustics treatments, and with digital room correction. What is novel is that I also recorded the sound of each of these using a set of in-ear binaural microphones so that people could listen to the sonic improvements themselves.
http://www.computeraudiophile.com/blogs/mitchco/importance-timbre-sound-reproduction-systems-222/
Cheers,
Mitch
Hey Bruce,
Cheers,
Mitch
Thanks Mitch... would love to read it but I've been banned from the site. He has my IP addys' blocked. Sorry
