I saw the first few posts on that thread - and I'm going to avoid it......
I think that Amir joke about the two tonearms comparison is too carefully written - we risk that people who are not following the other threads are taking it seriously!
Gary also did a test of the turntable vacuum system for me. I was very surprised that when he let out the vacuum pressure holding the LP down on the platter, all of a sudden I started to hear a lot of background noise (typical LP noise). And here is a fascinating psychoacoustics effect Bob Stuart of Merdian fame talks about: when he put the pressure back on, I started to hear the same scratches that I had not heard the first time with the same pressure on! While the level was much lower with pressure, the noise was audibly there. Yet, not knowing about it, had made me think the first time that it was completely absent. Once we get sensitized to an artifact, we can hear it much more readily. This also throws a monkey wrench into AB tests. Clearly my first observation was inaccurate since the noise was really there but I thought it was not!
Indeed I think that is also the angle Bob Stuart uses, talking about hearing guitar notes and such that were completely missed in previous listening runs. And how when you hear them with better equipment, you can go back and hear them still with lessor.Great to have your opinion about Gary room. I enjoyed your opinions about the precedence effect - I have written about it in the past, not about artifacts but about the opposite - exceptionally good events!
I am not informed enough to say . But on the surface I agree that a device designed to run with vacuum would not be in a position to work well without. Still, for someone like me who had no idea it would be audible in any amount, it was educational. I expected to hear warble and such from warped record, not the groove noise.it's really not possible to effectively A/B a tt platter with vaccuum hold down capability 'with and without'. the reason is that whatever is used for gasketing to retain the negative pressure will not be pressed down without the vaccuum. so your A/B has an additional factor in the platter-Lp interface and is not truely indicative of how it should sound without vaccuum hold down engaged and the platter did not have any vaccuum hold down mechanism. it likely even affects VTA and VTF to some degree.
maybe the TechDAS has technology which eliminates this problem; if so i stand corrected and would be curious to know about it.
So is vacuum hold down necessary for sota or not .....?
I'm concerned for Gary , what is he going to do ....
With an air bearing, a record weight is obviously not recommended as it could change the relationship of the air pressure and bearing tolerance.
The gaskets used on the Air Force One are very thin and very soft silicone, and is supposed to affect this only minimally. But, as MikeL says, it's not valid unless the gaskets are not there. For those who believe that vacuum hold-down sucks the life out of the music, TechDAS provides for 6 types of top platter, 3 with vacuum hold-down and 3 without.
BTW, I forgot to say that Gary's room was also one of my favorites. Sadly I forgot to take pictures of the rest of his room . Those speakers have incredible dynamics... Yet they don't have towering cathedral sound which I tend to dislike in larger speakers.
Gary, I was hoping that people would get my reference to the "great" micro/macro thread going on now. Nothing about the arms...
Gary, do you have more than the one platter? If you do, what is the sound quality difference?.
What is the opinion of Techdas on the sound quality of the 6 different platters?
Cheers
---- That is the strongest endorsement you can claim!
...Meaning that the music (listening) transported you where no pictures can! :b ...In heaven.
.... with angels singing
Let me tell you, it was night and day. Once you listened to this one, the other sounded like trash. There was no micro or macro dynamics on the other. [Amir, you're a real funny guy, I like you!] The cheaper one was harsh as if it was digital. You could literally hear the needle drag on the sides of the grove! Go back to the $35,000 and boy, what a revelation. Angles were singing and you were transformed to somewhere with less crowds than CES!
---- I believe that he spelled it "angles". :b
...But I did not bother of remanding* him about his spelling fault (typo).
* Reminding
Amir, thanks for a great write-up.
I would like to emphasize that the Graham Phantom is definitely NOT trash. Prior to hearing the Vertere, it was one of my two de-facto recommendations when my customers ask me for a tonearm recommendation depending on the turntable they were going to put it on. The other was the Roksan Artemiz.
It is a great tonearm, and I had optimized it to the best of my ability. We weren't even sure that the Vertere arm would be available for playback. Touraj was still building and tweaking it up to 5am of the morning before he had a 7:30am flight out of London. Then, when he got to Las Vegas, he discovered that his luggage had gone missing - with parts of the tonearm inside the luggage. So, until Touraj's luggage was found late Sunday night (good thing I persuaded him to fly in 2 days early!!) I was expecting to use the Graham to conduct the demos, and that was what I was optimizing the system for.
Well, you walk into a thread after not reading for a few weeks and what do you find? For the very first time anywhere, Amir has declared himself more informed than any of the thousands of very satisfied customers and a bunch of reviwers; namely, that my 20 years of effort in tonearm design is trash, barely better than digital. Not that I turn a blind eye to meaningful comments, but previously the word out there has been to the complete contrary of Amir's decree.
Unfortunately, that's one of the inherent problems with threads and posts; ANYONE with access to a keyboard can be a "reviewer" and do countless damange to someone's life work with a tossed-out impression, whether it's right or wrong. These people are more interested in their agenda and "discovering" something that's revolutionary than in getting it right. Not to say that the $35k arm isn't great, because it probably is. Although only hearing it for a few moments I could not really comment. (However, a few others who DID hear it - and who spoke with me later - thought it was thin, and overly etched - just goes to show one person's wine is another's poison).
So, who's right? It only matters what the listener believes for themselves, and in controlled circumstances with most chances of complementary (or non-complementary) products in the chain.
I don't recall if Amir or others on this thread came to visit us in the exhibit room on the 35th floor, where I was exhibiting the "Elite" version of the Phantom. This is an upgraded version that is inherently designed for the AF-1 turntable, and by many accounts, was among the best sounding rooms at the show (which included Gary's Genesis too, of course).. We are the official U.S./Canada/S. America agent for the AF-1, but as I mused before the show, the thread seems to suggest that we were not even in the picture at CES. Especially for the esteemed Amir, apparently...!
Oh well, can't please them all. Better to work on pleasing those who have an open mind, rather than those who decide they know more than the others.... "Digital" Bob G.
