I got to borrow the KLaudio cleaner for a day and compared it to my Audio Desk. I have to say I am impressed with it. It seems to clean a little bit better and operates flawlessly. Appears to be well built as well.
On my anticipated next failure of my Audio Desk whenever that is, I will be purchasing a KL
I have an update on the situation. I have exchanged many emails with Robert Stein today who assured me that my unit will be taken care of promptly. He also explained how it is the manufacturer who does not offer replacements for the machines in the field, so the distributor has its hands tied.
Also, after reviewing my math, I have $5375 invested in the machine not the $6000 I orginally reported. I had forgotten that I had bought my unit before the prices went up.
here's the latest (and hopefully the last) update on my situation with the audio desk systeme record cleaner.
Thanks to mr. Robert stein of ultrasystem (the us importer of the ad), i received a brand new unit on thursday. The serial number is in the 1900s (my original machine was around 1000). After cleaning 50-60 lps this weekend, i am happy to report that this unit is working flawlessly!
If you've never experienced what this machine can do, you've never seen a properly cleaned lp!
Joe, the issue you raised was one Fremer was speculating on, and I think Tim, from KL Audio, answered it here, and on Fremer's site. I'm using the AD. I buy a lot of older vinyl, most of it is 'supposed to be' in good shape, but you know that used record grading is pretty subjective. (Also, I almost prefer that sellers don't try to clean records or wipe them with lubricants to make them appear glossy- I'd prefer to deal with the record 'as is.') For that reason, if it is a grotty looking copy, I will pre-clean it before sticking into the AD. New vinyl, virtually never, but I will dry brush the detritus on a new record left from a paper inner sleeve if evident, just to minimize what I put into the AD.I too have been impressed with the KLAudio RCM. My concerns are the same with that unit as with the Audio Desk. That being the fact that unless you change the water in the tank with each LP, aren't you just recycling the dirt from the previous LP onto the next? I ask only because I don't have any hands on experience with either unit. I have used Keith Monks and Loricraft "string" cleaners and wand based units from VPI and HannL GmbH.
My current machine of choice is the HannL, with its ability to vary the speed and direction of the platter rotation and the intensity of the vacuum. Using the Walker Prelude 4 step method and the HannL have resulted in very clean and very quiet surfaces, and a thorough drying process.
How many times can a record be subjected to ultrasonic bombardment before disintegration starts occurring?
I ask this as I have a ELP laser player which requires every side to be cleaned prior to playing.
The people at KLaudio cleaned an LP for 9 hrs straight in a heated bath with no ill effects.
I have to ask, once you clean an LP, when do you have to do it again ? With so many selections and my meticulous record handling, I see going 2-3 years if not more before you would need to clean it again and that is playing that LP at least 15-20 times.
I wonder if it is possible to use the AD without any surfactant? (Assuming a fresh set of roller pads).
I'm sure you can with the AD but according to what I know, it would compromise the sonication eg. the surfactant lowers the liquid's surface tension allowing the unit to work more effectively. I would tend to agree with Jerome as that was what I hypothesized might be the sonic difference between the two machines. The best surfactant is no surfactant. If you look at their chemistry, you can see that they greatly vary in terms of the number of washes needed to completely eliminate the surfactant. (of course, in many cases, these surfactant's interfere with enzyme activities.)
I know for a few years that Albert Porter was using 2 AD's, with one for wash and the other with pure water for the final rinse. I suppose a person could use de-ionized water for the rinse to reduce water residue.
I use one cap full of the standard detergent and have found that that amount works well with the AD. until I went to that approach I found with more detergent that the results improved as my water lowered and I topped up a few times (the detergent got more diluted). I kept reducing the amount until I got to a cap full. less than that and it did not dry quite as well.
