Avalon Tesseract
Sorry Neil but your speakers really are spooky. I always found the Isis and Sentinel grand in an ancient aliens kind of way but these........
599433_479351325516580_1894443865_n.jpg1456555_479351245516588_1694204058_n.jpg1460942_479351178849928_916261573_n.jpg1461675_479351122183267_1346709590_n.jpg
Thanks, Jazzhead - any initial word on how they sound?
Those are much better pictures Jazzhead. In a different color they would blend into that room much better I'm sure. The bass cabinet is huge. I bet the bass response is epic. I wonder if the bass response is adjustable?
Thanks for the pictures Jazzhead. Were they using Nordost cables? We can see Lars Christensen on the left of the first picture.
Pleasure Sir .. No ZenSati No.1 was the cable in use for the Tesseract set up . Lars was there for the Raidho room , Nordost was used in the rooms below :1463069_478975395554173_798861249_n.jpg1482898_478975858887460_732112273_n.jpg1455175_479351462183233_1570939788_n.jpg1476571_479351185516594_1017207343_n.jpg1455034_478975798887466_335601752_n.jpg
Slightly OT . apologies .
1470050_478975245554188_712565107_n.jpg1474484_478975335554179_31495178_n.jpg1470191_478975268887519_114146946_n.jpg1468603_478975668887479_2093459916_n.jpg
1467281_478975432220836_623076764_n.jpg1462878_478975405554172_320400557_n.jpg1453362_478975732220806_203345457_n.jpg988378_478975612220818_917994271_n.jpg1464684_478975795554133_270384460_n.jpg
Awaiting the Tesseract .
Lars has his own cable line now called Ansuz.
Dear Jazzhead,
Could you please share with us if the cabinet of Tesseract is made of MDF? Or other material?
Thanks !
Kamil
Dear Jazzhead,
Thanks !
Kamil
This is all I know ...It does seem that the bass response can be tailored , no mention of cabinet construction though , my guess would be MDF with a high degree of bracing of varying density , if their past work is taken into consideration . Avalon at least till now, do not seem too keen on other exotic material .
