American Sound AS-2000 Installations- Far East (Tango)
13m here, no issues,.Still, hum is one of those mysterious beasts. Good luck Tang!
Different cables will have different parasitics. I suspect Micro's cables have inductance that creates a different ground potential at either end, and since the equipment isn't effectively "floating" the circuit ground, that's a problem.
Mike's preamp is battery powered so it's a special situation where lifting grounding plugs makes sense.
You had to lift the ground or more than that?
david
I had to lift all the grounds, but because the Hospital Grade Receptacles are double and share the same ground we can only use one half of each . As I get annoyed with the disagreeable electrical leakage shocks every time we disconnect any of the RCA cables (230V has a much higher leakage) I am using some back to back diodes to connect the ground - it is also good to keep the safety of the system.
Yes, if one choses to cut off the third prong from a pricey power cable, more power to them! As you say, it probably does not comply with the electrical code pretty much anywhere (in the US). So I prefer the grounding scheme in the equipment instead be designed such that the audio ground is not shorted to chassis electrical ground, and these issues are avoided in the first place.
Unfortunately I think it is mandatory in EC regulations. You can't have floating accessible connectors such as RCA's.
No, the problem exists because the Lamm preamplfiers are mono units using separate power supplies. Once we connect two power cables with grounds we are establishing an enormous ground loop, unless the source are also separate floating mono blocks. The worst case is using separate direct lines for each amplifier!
I also have the Lamm L2 preamplifier and the hum problem does show with it - it is a stereo preamplifier.
Right, agree. And adding the diodes or resistors as you've done should also not be the responsibility of the user/owner. The equipment manufacturer should have the resistor or diode circuit internally. It will eliminate ground loops and prevent people from needing to use cheater plugs, disconnecting ground wires in the wall, etc.
Because the Lamms must have the audio and chassis grounds shorted.
You need at least one grounded component, you shouldn't have any leakage then. My experience is that only the amps need to be ground lifted all other components need to be tested first. Start with the amps and then only connect the pre without anything connected to it, check and see if you get hum with the grounded pre attached, if not continue with other components and try them both grounded and not, you should be able to find one that doesn't induce hum when grounded.
david
How many do this? It’s easy to stop loops without lifting, in linear PSU gear. And you don’t have to change the schemes in the gear.
david
Yes, I did all this sequence with a floating spectral analyzer connected to the amplifiers output and had success. But I would not feel comfortable with a ground lifted mains distributor with equipment having very high HV inside.
Very cool, and good idea!!!
The mains distributor should be grounded just individual component's ground lifted.
So your conclusion was that you can't have any component grounded?
david
You have to do this if needed and also some components sound better with their ground lifted.
How do you fix ground loops easily without lifting and/or adding inline transformers?
david
david
There's a specialized inductor that works great in the audio+ band, but saturates immediately and can allow a full short to pass while the breaker turns off.
david
Yes, for minimum noise only the sources ( DAC and phono preamplifier) should be grounded. Systems using cables with light shielding / return wire are particularly sensitive to ground loops. I do not have Kubala Sosna Elations any more, electrically they should be excellent for the Lamm's - I remember that the resistance of the ground wire was very low.
My interconnect from preamp to amp is also 13 meters Jack and zero hum
I don't actually think there's any need to not ground anything. But some designers have very... various ways of causing problems with their ideas of grounding.
we had multiple pages in my amp comparison thread on this subject. i just used power plugs with the ground pin removed. zero noise.
typical of what keeps most tube amps quiet in my system.
Loud hum at first and I did just what you said. Hum is gone.
Thank you Mike
Tang
