The first Totaldac D1-Twelve Mk2 DAC in Hong Kong
GuillaumeB
268
89
333
UK
www.boyeraudio.com
preliminary specs are:
stereo power amp
RCA inputs
big Mundorf binding posts
220mm height + feet
500mm width
410mm depth
50kg
big power supply transformer
2*150W under 8ohm
2*270W under 4ohm
2*500W under 2ohm
stable under 1ohm
1.6V sensitivity
47Kohm input impedance
no global feedback
fully discrete design
triode input and solid state output
class AB (with medium level of class A for moderate heat)
wide frequency bandwidth and low noise
Very good specs, I am looking forward to hearing this!
Guillaume
b360
4
Vincent,
Are you still collaborating with Absolare?
Look forward to hearing these new products. So many upgrade paths to contemplate. Complements on the visual design as well. Very interesting extension of your design vocabulary.
Wishing you much success.
J
totaldac
570
708
1,155
France
www.totaldac.com
Vincent,
J
Thank you very much. Yes I am still demoing the Absolare push pull 845 amplifier for my d150 speakers and the large horn coax system, and still demoing Echole cables used in all my demo systems. For the Magico M6 I prefer the transistor drive capability.
totaldac
570
708
1,155
France
www.totaldac.com
totaldac
570
708
1,155
France
www.totaldac.com
A third room at Munich Hifideluxe show will use this point source speaker:
http://camerton-audio.com/binom-1
jackson_k
83
17
90
Los Angeles
Ive heard several of the pres you mention above and the CH Precision is the most quick / responsive dynamic and real sounding I've ever heard. There's no sugary tubeness but if you want to get the closest to a live band in your room, this is it, IMO. I hear with the mono amps combo it jumps another level.
Guys so how does TOTAL DAC stack up against MSB Diamond DAC? I owned Diamond DAC for a while a few years back , and just wondering how does it compare to it. Cheers,
CKKeung
3,063
3,201
1,410
Hong Kong
Hello Jackson,
Your past dac was MSB Diamond IV or IV Plus or V?
And what's your current dac?
jackson_k
83
17
90
Los Angeles
Hello Jackson,
I had the DIAMOND IV when it first came out : ) ,,,, right now... hahahahah man it might sound backward to you guys , but I am using a DATASAT RS20i as my DAC / processor ,,, because I wanted to try Dirac and try to see if I can optimize the room through Dirac and also because I wanted to add 2 sub and blend it into the system as smoothly as I can ,, but I am also looking into using the Digital out from the RS20i so I can run dual DAC for the HF/ LF as well if I wanted to go a little crazier : )
totaldac
570
708
1,155
France
www.totaldac.com
Hello,
For those who want to make EQ, room correction, sub management and so on, the Totaldac streamer board now embedded NAA firmware, to be used as a sound receiver for the software HQplayer.
Taiko Audio
4,314
13,458
1,925
The Netherlands
taikoaudio.com
I received these Bibacord AES/EBU cables from Vincent 9 days ago.
These do need considerable burn-in and/or settling time. Initially I was a bit underwhelmed by their performance, so I put them on my Audiodharma cable cooker for 3 days and then reconnected them for another 6 days of normal system time. This did make for a rather dramatic difference to their initial performance.
No doubt this is a considerable upgrade over the stock supplied Totaldac AES/EBU cables. It does have it's own distinct character, from their website: "Conductors are solid core OCC copper with cotton insulation." Despite being AES/EBU cables they sound somewhat similar to analogue cotton cables, those who have heard cotton dielectric / damped cables will know what I mean by that.
On to what they give you over the stock cables:
-Considerable increase in high frequency micro detail and delicacy
-Better midrange articulation, especially noticeable on piano and voices
-A more 3 dimensional rendering of individual images within the soundstage
-Better rendering of texture on individual images
-They add additional depth to the rear of the soundstage without changing the overall perspective
-Bass and lower midrange are "rounder" sounding, slightly loose but stronger, it adds a nice "warmth" to the presentation
-Together with the additional bass/lower midrange warmth and a softer high frequency presentation it makes for an excellent "digital sound" cure. It provides a very relaxed overall presentation and reduces listening fatigue on prolonged listening sessions in harsher sounding systems.
Although they really provide a very considerable upgrade over the stock cables, I will not purchase them, as there is a negative aspect to them for my personal taste, which is a reduction in open air live recording realism. For these I prefer the stock supplied cables for providing a more euphonic and exiting presentation. Audience applause for example is a bit softened which diminishes the realism for me. For anything else, jazz, blues, studio or indoors live recordings, which are more damped sounding by nature this is not an issue. If this is not a problem for you, I would have to say the ~Euro 2000 retail tag for a pair of these is worth the investment.
Reactions: CKKeung
totaldac
570
708
1,155
France
www.totaldac.com
updated
preliminary specs:
stereo power amplifier
RCA inputs
large Mundorf binding posts
no global feedback
class AB with medium level of class A for moderate heat
designed on Magico M6 and on a 105dB large coax horn system
2500VA and 26kg "live-power" proprietary power supply transformer
2*150W under 8ohm
2*270W under 4ohm
2*500W under 2ohm
stable under 1ohm
28dB gain
1.5V sensitivity
frequency bandwidth at -3dB: 0.06Hz to 120KHz
250mm height including feet
483mm width
453mm depth including connectors
weight approx 50kg
price 18900€ incl VAT in Europe
BF38
168
44
113
Yumyum... in a hurry to be at the Munich de luxe show to listen to this new sound architecture !
a little idea for the first availabilities of this Amp-1?
totaldac
570
708
1,155
France
www.totaldac.com
As I answered in a French forum, it should be shipped around September.
totaldac
570
708
1,155
France
www.totaldac.com
New photos of the preparation if the Munich hifideluxe show.
Using Magico M6 speaker, sound to be compared to MSB Room and Soulution room also using the M6
BF38
168
44
113
nice !
Kris
956
975
183
Hi Taiko Audio
I tested bibacord from vincent on my totaldac24 and yes this are great cables. Unfotunate not perfect.
I also decided Not to buy them because they missed the live like reproduction.
I puchesed few Absolute Creations TIM signature XLR digital cables.
This is gigantic improvement over the standard cables.
And they are the only cables that keep this fantastic transparency and live performance and adding the most emotional reproduction ever . Magical 3D.
Also I used the different BNC cables for clock and this gives the most of transparency and detail in the system.
Additinally I exchanged digital volume controll cables for custom made and shilded.
Big improvement.
Actually I was planning to test your Extreme and I requested it via email so there is a good chance for you to visit me with extreme and try to hear difference with original cables versus AbsCreation and Custom bnc cables / custom rca cables for titaldac.
