Wow the joy on that girls face and her technique........
Do @audioquattr and Vlad have the same experience with their bass horns?
OMG! That photo is incredible. I will check out the video later. Thank you for sharing.
Hi, Bonzo!
The nice thing about Ralph’s horns and the bass amplifiers is that you are free to adjust crossover point, filter slope, phase and level in a fairly wide range. As I listen to a wide variety of music, including rock and electronic I have my crossover point set on the higher side - i.e.at 115 Hz - and at this point you can hear the bass horns playing if you turn off the main towers.
For purely classical music I think I would have followed Tang and set the crossover to a lower frequency which would indeed just provide the fundamental tone/ambience but should generally be inaudible otherwise.
Phase adjustment does make a difference for mid and high-frequencies clarity - I switched the bass horns to -90 phase as the bass speakers (not the horn mouth, specifically the TAD speakers inside the horns) are roughly 1 meter behind the mid-bass horn speaker in the main tower in my case.
If you have at 115, at what point do you stop hearing them if you turned it downwards?
Hi, Bonzo!
The nice thing about Ralph’s horns and the bass amplifiers is that you are free to adjust crossover point, filter slope, phase and level in a fairly wide range. As I listen to a wide variety of music, including rock and electronic I have my crossover point set on the higher side - i.e.at 115 Hz - .
@VladB. Do you do server or disk drive mostly on digital. Can you describe your digital front.
off the top of my head......
Ben Webster, 'Live at the Renaissance'
The Sonny Clark Memorial Quartet, Voodoo (a little hair shirt.....and hard to find an original pressing)
Art Blakey, 'Moanin'
Thelonious Monk, 'Monk's Music'
Dexter Gordon, 'One Flight Up'
anything by, Bill Evans, 'with' Lee Morgan, or 'with' Coleman Hawkins is a no brainer. got to have some Count Basie Pablo's.
a nice Jazz album i just got that was recorded to, and mastered from, tape......fantastic piano and horn sound. anyone who thinks digital can do dynamics needs to listen to this and find me a digital match. i don't have one.
https://store.acousticsounds.com/d/125556/Ferit_Odman-Dameronia_With_Strings-180_Gram_Vinyl_Record
