Lampizator Valve / Tube Rolling Review Thread
adamaley
588
546
228
Minnetonka, MN
Look into getting a set of Tesla AD1n and never look back like I did. I also had distortion with the 242s, less so with the PX25s, but it was still there on some songs and you were always anticipating it to come spoil the party.
The Acme 300bs were my favorite for a while. They do everything well. Compared to Elrog 300b, EML XLS 300b, KR 300b, 242, PX25, PX4, they were resolving, very quiet, yet still delicate and nuanced. Until the AD1ns showed up. These are just as good but with more note continuity, resolution, and a unique ability to render fully formed 3d images compared to any other tube.
For context, I have a GG2, with volume control, reduced gain for the 242, and still had gain issues. A low gain preamp helped some, but it was still not attenuating enough.
My go to rectifiers are, in order of preference, the WE 274A, WE 242, and Acme 274b.
wisnon
3,536
640
1,200
I tried PX25 with Momentums. There was distortion due to high gain. You are obsessed with 242 and pretend not to understand the gain issues it creates in most systems. My dac was voiced with 300b, which is quite annoying considering the fact it is not the best sounding tube for Lampi. Now I need to send my dac to Poland to get the best out of it after I already paid almost 15k? Maybe I should look at other dac options instead.
Attenuator plug?
wisnon
3,536
640
1,200
Guys, I need your help! I currently use Tak recti with Tak 300b on my GG2. The timbre is nice, but sometimes I wish for more resolution and a better defined bass. I also have 242 and PX25. They a better resolving, but the gain is too much in some situations. I plan to send the dac to Poland to install the high / low gain switch.
Until I do that, I would like to find another low gain output tube, which is better than 300b. Does it exist?
EML PX4, EML mesh 2a3, NU 45, EML mesh 45 anniv globes, EML 25th anniv solid plate 45. Tesla AD1n.
Reactions: abeidrov
iain
38
16
115
Attenuator plug?
Phono plugs with a resistor in them to attenuate the level. I don't have any distortion from my 242s. But can't turn the vol low enough. I used the digital vol in Jplay, but have to up sample to 32bit for that to work. so I tried the plugs and prefer them. I am happier without the attenuation, but my missus isn't!
wisnon
3,536
640
1,200
Thanks... I know what they are. was just suggesting them to Abiedov. I appreciate youelr account of your expeience with them though.
Reactions: iain
dminches
3,483
2,859
1,410
Unfortunately, one of my Tesla AD1ns is bad. I have only put about 10 hours on them but I noticed a big channel imbalance which swapped sides when I swapped the tubes. I tested them in my Jackson 648 tester and the results matched what I am hearing. There aren’t really settings for AD1s for the tester so I tested them a 4V 300Bs.
I hope Lukas makes good on them.
Golum
1,814
2,577
405
Lausanne, CH
Crap :(...did you contact Luke regarding this already if you got them from him?
I do hope it gets solved quickly...
dminches
3,483
2,859
1,410
Lukas and I have exchanged emails. He will try to find a replacement. It seems like finding a nice, clean pair is not easy. There have been some issues with other AD1s.
Zero000
2,988
1,141
478
Lucas is an OK seller so hopefully he will come up trumps.
It's such a simple construction internally it is hard for them to go wrong I would guess.
I sold a pair of RD27AS to someone who insisted one was faulty. I asked him to send it back and it was absolutely fine and still is. A very curious mystery. He had even taken it to his 'tube guy' to have a look at.
I have given it a few firm taps etc etc and I just cannot get it to malfunction.
Strange indeed.
Tip: make sure the pins are clean with Deoxit and swap them in their adaptors. if that doesn't work, file the tips of the pins very slightly. That sorted out a Loewe AD1 I have.
dminches
3,483
2,859
1,410
Strange indeed.
I cleaned the pins with fine sandpaper. I don't see any oxidation on the pins. I have tried 2 different adapters. Same result.
Zero000
2,988
1,141
478
Bad luck:(
I must admit I am surprised you have had more than one issue with them. I have 7 Tesla AD1 and all are fine.
dminches
3,483
2,859
1,410
Bad luck:(
I think you need to sell a pair to fund something else.
Zero000
2,988
1,141
478
I am a bit wary after the RD experience...
I will sell you one if you have one that works. If you give me that mA/V reading of it I can send you something close to it I suspect.
bonzo75
22,651
13,688
2,710
London
I was expecting you to add your drum track video to the Rock and Drum videos thread
Zero000
2,988
1,141
478
I deleted all my Apogee videos from YT.
If I can find it I will.
I seem to remember I posted the video and an audio file recorded on a Rowland which sounded 83,192 times better than the camera mic a while back.
I might splice that into the video.
bonzo75
22,651
13,688
2,710
London
You can just post the file. What is a Rowland
Zero000
2,988
1,141
478
Rowland make all sorts of studio kit.
This particular Rowland is a digital audio recorder. Had it years but it really is a high quality sound recorder.
I basically bought it so I could hear myself playing the guitar through the hi-fi.
bonzo75
22,651
13,688
2,710
London
Amazing. So you built your own speakers to hear yourself playing you. You should also put a mirror in between the panels to watch.
Can you please do me a mobile vs Rowland of the same track?
