Keith's Dream Amplifier Thread
christoph
4,688
4,074
825
Principality of Liechtenstein
But Keith added a tube preamp as well?
That was what several suggested from the beginning but Keith insisted in keeping his passive attenuator as a fix point iIrc
rbbert
3,820
239
1,000
Reno, NV
So will this thread be revived? Any thoughts on Vitus? DarTZeel? tubes?
thedudeabides
2,195
710
1,200
Alto, NM
Bill Parrish / GTT Audio uses Audionet.
musicfirst1
504
310
395
Canada
www.musicfirstdistribution.ca
After extensive North American travel to hear multiple home based, manufacturer and dealer showroom based systems as well as too many shows to mention, I would recommend two diametrically opposed amplifier brands to auditon:
Aries Cerat
Audionet
I also think Pilium may also be very good, but I heard it in a system with unfamiliar components.
I have both AC and Audionet in my personal/reference system.
213Cobra
328
344
148
69
Los Angeles, CA
May be keith is also going retro / vintage . :)
Well, ultimately that's up to him. Right now Ampzilla has to be beaten, which it could be. He's moving to higher-efficiency / lower drivers-crossover-complexity speakers. This opens up viability for lower-power, more reliable tube amplifiers. So much remains to be settled in the reset. Keith is inclined to SS for good practical reaons, but I'll be bringing around some custom tube amps -- single-ended-pentode, push-pull triode and pentode/UL to gauge interest and satisfaction with against mainstream options. Greater speaker efficiency / reduced xover-drivers complexity yields more practical, musically-attantable options.
We're 14 minutes apart in normal traffic, even in Los Angeles, so comparisons like this happen sometimes.
Phil
213Cobra
328
344
148
69
Los Angeles, CA
That's my experience too. For about 50 years, but really more. I've never been shut down for music access because of a tube failure. However it is decidedly not Keith's experience. So the outcome may very well not be tubes-fueled.
Phil
Reactions: Lampie519
Lampie519
493
347
65
58
Hoofddorp, Holland
Still waiting for a tube failure in my amps (salvaged tubes from old TV sets 30 years ago).
PL519 tubes, naturally ;-)
213Cobra
328
344
148
69
Los Angeles, CA
I get it. PL 519. TV sweep tubes unchallenged by hifi. Julius Futterman thought the same way for his OTLs.
Vacuum tubes chosen well for a circuit are incredibly durable despite the visual vulnerability of being glass enclosed. Example: In place of 5687 tubes I sometimes use 6900s. This tube was developed for ICBMs, with a Nonex glass envelope (non-expansion glass) and 500Gs survivability. It looks as vulnerable as any other glass envelope small signal triode, but it's nearly indestructible in use.
Phil
Lampie519
493
347
65
58
Hoofddorp, Holland
In my amps they drive my ESL's directly (5KV p-p). No stress for these guy's what so ever.
Unfortunately i had to replace some in a Futterman based OTL the other day (after 15 years of use).
Reactions: GMKF
KeithR
5,174
2,861
1,898
Encino, CA
as far as tube trials and tribulations, i've probably had a half dozen issues over the past decade. if I was to try one it would be the matching LTA amp. but honestly, i prefer SS at this point.
Lampie519
493
347
65
58
Hoofddorp, Holland
I think the LTA amp could be a nice addition, at least try it once.
Failure of equipment is no fun but the pleasure it can give if all works at its peak is rewarding.
Nobody complains about replacing tires on a car, or even if it breaks down.
If you love your car you repair it , over and over again.
Funny that this is not the case with audio stuff.
Reactions: GMKF
KeithR
5,174
2,861
1,898
Encino, CA
I would agree, but you are likely not disabled and require help to get things fixed such as myself. The LTA is only 15lbs so its possible I could do it.
Lampie519
493
347
65
58
Hoofddorp, Holland
Beeing disabled is something else (i did not take this into account).
It is true that i am able to fix most audio stuff myself. Not so with cars (and i am unfortunate to love my car).
I think that Zotl is the answer to lightweight audio nirvana....
rbbert
3,820
239
1,000
Reno, NV
Any new amplifier thoughts now that the Fynes are dialed in?
steve59
356
112
150
bump, The Mc611 are solid and very dynamic at low volumes and in todays market priced within reason for what they offer,
