FTA (Final Touch Audio) Callisto USB cable
LampiNA
350
874
335
Yes, the Callisto is a very special cable. Unfortunately, however, we are limited to a 1.3m max length due to its construction and geometry.
I wish we could offer them in longer lengths, but our quality standards won't allow it.
Reactions: Golum
Stei7141
10
5
133
OK, thanks for the quick reply!
Kingsrule
1,445
704
1,430
Hi Fred
Do u have them in shorter lengths, say .25m, .3m or .5m and that are instock?
LampiNA
350
874
335
We can build them to a custom, shorter length, but as far as inventory, we primarily stock 1m as the standard length.
Reactions: Golum
Golum
1,817
2,577
405
Lausanne, CH
Jumping in here, excited about Callisto, as most USB cables out there just don’t do it for me. I wonder if Callisto can be had in longer lengths (3M would be of particular interest), and whether you anticipate any sonic “penalty” for the longer run? Many thanks!
Michael
Hi Michael;
Thank You for the interest in the cable. Lengths we do the cable vary from 0.75m to max 1.3m as above that we notice SQ deterioration so we decided not to produce longer runs. Apologize if we can't be of any help.
Stay well and all the best;
G
LampiNA
350
874
335
Congrats! We know you will be pleased. It should ship in the next business day.
Reactions: Re-tread and Golum
LampiNA
350
874
335
Reactions: gestalt
LampiNA
350
874
335
Thanks! I will check it out.
On a side note, I ended up with two FTA callisto usb cables (sotm to Innuos Phoenix, and the phoenix to singxer su-6), and also the FTA ethernet cable for EtherRegen to sotm. Lovely combo.
I recently purchased a sablon 2020 usb. Long story short, I like the FTA Callisto more. Sablon feels a bit more emphasis on the highs, whereas callisto has better bass and mids, which is my preference.
Thanks for sharing your feedback. Would you have any interest in checking out one of our Elara power cords? We would love to get your thoughts on that.
Where are you located?
LampiNA
350
874
335
Thank you. Is there any tracking info available?
The tracking info should have been entered through the checkout portal, but if you want to shoot me a PM with your name, I'll look it and and send it to you again.
PhP
188
123
950
FRANCE
www.phpaudio.fr
Hello,
cables is an interesting subject, also the door of beliefs. I have listen to many power cords, interconnects, speaker cables, digital cables for 40 years, and yes also to USB cables.
About USB cable, I must say that audiophile cables are often better than computer ones. However, if the best I listen to is PRANAWIRE's Photon, I become aware that when the transport or the network player is well designed, I found no real advantage between a very good USB cable from the computer world and an exotic cable from well known manufacturers. This is not the case with other cables, power, interconnect and speakers cables where high-tech is mandatory.
highstream
1,106
438
488
What is an example of a very good USB cable from the computer world? Since computer audio has become popular, better quality computer cables are designed to sound as good as audiophile stereo system cables.
PhP
188
123
950
FRANCE
www.phpaudio.fr
Hello Highstream
In the past I used VooDoo reference silver USB after some years with PAD USB. PRANAWIRE Photon is much better than all the cables I tried.
I do not use anymore my MacBook Pro in the audio system since the introduction of MAN301, I use computer quality USB cable from SAMSUNG. There are few high quality USB cable with USB-C, and to my perception, more marketing at a cost than pure engineering.
I do not detect a real improvement between computer cable and audiophile cable sound in this ripping / replay application from MAN301 to Samsung SSD T7. But I will try the PRANAWIRE Photon USB-C to USB-A version when it will be available to verify if I could get a better sound in my application, or find that it is useless and a loss of money.
Last years, I linked my MacBook to my previous BRICASTI M1 DAC, and found that USB cable quality was mandatory. WEISS MAN301, latest version is a surprising unit, it blows away my previous STAHL-TEK CDT at 1/3 of the price, and seems to be less digital cable dependent especially in conjunction with DAC 502. Daniel WEISS recommend to use computer quality cable in USB or RJ45, and their digital cables are special wires with Neutrik (XLR) or Furutech (RCA) plugs, unshielded. Daniel received a technical Grammy award this year .
Cheers from France
highstream
1,106
438
488
Along with a few others from the Cable Co., I tried the PranaWire spdif cable and was unimpressed. I ended up with the PAD Neptune, which I still use between Oppo 203 and Lampi dac. To each their tastes. As for USB, I used the TotalDac in my computer audio system for a long time -- JCAT card to Directstream dac, before disassembling the system and switching the cable to an SSD to Oppo run in my living room stereo set up. Currently, I'm using the Callisto in that spot. However, a recent comparison of four USB cables by someone on these forums found the FTA was "shouty" in his system, which is something I also experienced upon its arrival -- and have mentioned a bunch on the Lampi TRP forum. But since I had changed some key tubes at the same time, and have seen the shoutiness wax and wane with different tubes, I've assumed it is tube related, not the cable. I'm going to find out: the favorite in that comparison was the basic Curious USB, which years ago I wasn't all that impressed with on my desktop. They have an "Evolved" version now and I'll soon be auditioning a short one to see how it fares.
Reactions: christoph
PhP
188
123
950
FRANCE
www.phpaudio.fr
Along with a few others from the Cable Co., I tried the PranaWire spdif cable and was unimpressed. I ended up with the PAD Neptune, which I still use between Oppo 203 and Lampi dac. To each their tastes. As for USB, I used the TotalDac in my computer audio system for a long time -- JCAT card to Directstream dac, before disassembling the system and switching the cable to an SSD to Oppo run in my living room stereo set up. Currently, I'm using the Callisto in that spot. However, a recent comparison of four USB cables by someone on these forums found the FTA was "shouty" in his system, which is something I also experienced upon its arrival. But since I had changed some key tubes at the same time, and have seen the shoutiness wax and wane with different tubes, I've assumed it is tube related, not the cable. I'm going to find out: the favorite in that comparison was the basic Curious USB, which years ago I wasn't all that impressed with on my desktop. They have an "Evolved" version now and I'll soon be auditioning a short one to see how it fares.
I had PAD Proteus RCA in the past, it was a good cable at the price between my STAHL-TEK Vekian DAC and my NAGRA preamp, but a bit colored and not as detailed / transparent as I want (I was PAD dealer at that time). I still have an interconnect from PAD.
Cables burn in is very important (depending on the design and on the materials used), and sometimes cables can reveal problems in the audio system. I never listen to PRANAWIRE spdif, but only to Cosmos II in XLR, and it's really a great cable. However I sold it to upgrade to Arhat.
christoph
4,690
4,078
825
Principality of Liechtenstein
Curious to learn about your findings? ;)
