Found new open box KL Audio Record Cleaner on sale
astrotoy
1,551
1,020
1,715
SF Bay Area
sombunya
133
8
325
I see it's been discontinued, a great reason to buy it and save money. It says no special cleaners or detergents. Does that mean it uses only distilled water?
I only ask because I wouldn't rule out buying one myself.
tima
5,869
6,944
1,400
the Upper Midwest
Yes - it uses only water, preferably pure. However, you cannot clean optimally by smacking vacuum bubbles at records alone - imo surfactant is needed.
sombunya
133
8
325
No reason to buy a KL with Degritter around. Had both.
You say you've had both. I'd be interested in your comments on them and why you prefer one over the other.
djsina2
1,172
1,018
243
1. Degritter is fully controlled and customizable via updatable firmware
2. KL has no inline filter, Degritter does
3. KL is a hassle to fill and empty, Degritter has removable tank
4. KL has no (reasonable) way to clean the tank
5. KL is much noisier than Degritter
6. Degritter has excellent support, KL was MIA when I emailed them
sujay
516
219
955
Singapore
I would also go degritter.... I had KL which served me well for 4 years. Then it suddenly stopped functioning. I had a terrible time liaising with the factory in Seoul and despite all efforts they were unable to repair it. So I decided not to spend anymore time, effort and money on it. .....
For what the KL unit costs, I frankly expected it to be more robust.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
owned my KL for 10 years; it's been flawless.
agree it's more for maintaining clean records (or touching up new records), not really for cleaning snarly dirty records. would choose a Loricraft for that, which i've owned i n the past. if i bought a large used collection i'd likely buy another one.
for me it does give me comfort that Peter (designer/builder of KL) is a friend/local person who i know, been to my home multiple times, so if i did have an issue i can get support. but i've never needed it.
Reactions: Steve Williams
Mine has worked flawlessly as well for over 6 years and I've never had a problem
