Thanks ICUToo:A5s out of the box sound TERRIBLE.
No liveliness, no bloom, no beauty.
They need a few hours at high volume to sound ok, then a couple hundred more hours before you realise that they have disappeared completely, leaving behind only the music.
They disappear like few others, and top-to-bottom take on a neutral, fast, accurate but NEVER nasty mien, with a beautiful natural midrange. Good wide-range frequency response- I actually prefer than without subs as the bass is so fast (not to say that excellent subs to fill the lowest lows wouldn’t help). Easy to place in-room for tonality, but quite fussy for perfect imaging.
And that’s driven with a solid state amp.
Make sure you hear a run-in sample- I was shocked at how awful they were at startup, compared to the ones I had heard at the shop.
All the best.
Have you tried putting the spikes on the A5's vs just sitting on the carpet. It will make a fairly significant difference, along with another 150 hours.I understand speaker placement. However that said it’s not always aesthetically pleasing to move the speakers out I the room. That was the reason for the purchase in the first place.
I had replaced the 801n’s with something new at my primary home so I brought the 801’s up to my lake home. They were way to large for the remodel plans that we have for the main level of the home. I called The Listening Room in Chicago inquiring about a different speaker. The salesperson talked me into the Magico and said I would “Love Them” and they would work in my home much better than my current speaker. Didn’t work out that way so fare.
I understand they will get better with brake in and I did move them around just to see what a difference it would make. Some not much so I moved them back to make the wife happy.
I will continue to pursue this for a few more days and see what happens.
in the end I can trade again I guess. We will see. Thanks for the help and advice.
BEST!
KP
Rhapsody,Have you tried putting the spikes on the A5's vs just sitting on the carpet. It will make a fairly significant difference, along with another 150 hours.
The A5's CAN be placed against the back wall with the sealed cabinets, although if both speakers are in the corners of the room, I'm not sure you are going to get "good sound".
That's a job for Peter's corner horns
I don't think the spikes will change the efficiency of the speakers 1%. The spikes, especially on a carpeted floor, will improve the overall bass performance. Improve the bass performance and it will also improve the midrange, high frequencies, as well as tonality and your soundstage. Bass is everything!Rhapsody,
I agree on the spikes. That makes some difference. hopefully improve efficiency buy at least 40%. I think you really helped me make my mind up to trade these thing off. Or I guess I can sell the house…LOL
the house has corners for sure. My 801N’s performed beautifully in the exact same position.
just not going to work in my situation i think.
this speaker is just way to sensitive for me.
I have never owned a horn speaker…who knows maybe…LOL
Not much air or sense of space. like I said my wife who knows very little about audio other than what she likes. “The 801n’s sounded like a live concert, these just sound like ok speakers“ she walked out of the room and didn’t even listen.What about it don’t you like?
Thank you Rhapsody.I don't think the spikes will change the efficiency of the speakers 1%. The spikes, especially on a carpeted floor, will improve the overall bass performance. Improve the bass performance and it will also improve the midrange, high frequencies, as well as tonality and your soundstage. Bass is everything!
The A5s are high resolution speakers for sure. They are going to tell you what is going on with your placement in your room and with your system/cables etc.
I was just trying to offer assistance from afar, but would need to see the complete room pic.
Also, as we have said you need at least 200 hours on the speakers to tell what they are going to sound like. You do NOT have to play at high volume during the break in period.
Well, Precision Audio/Video is the only Chicago Magico Dealer in Chicago.Not much air or sense of space. like I said my wife who knows very little about audio other than what she likes. “The 801n’s sounded like a live concert, these just sound like ok speakers“ she walked out of the room and didn’t even listen.
The 801 had massive bass and a huge presence. The worst part if you can believe it were much more efficient. I feel like the A5 turned my 611’s into MC300. How depressing is that.
I never said that someone else did. To me that was never the case. When I first set my A5’s up I was amazed at how good they sounded out of the boxes. But they do get better with a couple hundred hours.Rhapsody, good point about being used. I can understand a new speaker sounding different, but “A5s out of the box sound TERRIBLE.” does seem extreme.
As a matter of fact, when I received my first pair of A5's, out of the box (in a very mature/well set up system), after listening for 30 minutes, I called Alon and said WTF is going on. I was SO amazed, right out of the box, by the mid-bass and mid-range transparency. It superseded what I was use to with ANY speaker in this respect.Rhapsody, good point about being used. I can understand a new speaker sounding different, but “A5s out of the box sound TERRIBLE.” does seem extreme.
I went to my local dealer to hear the A5. I owned Q3s at the time and read all this great stuff about the A5. When I told dealing what my system was he told me I wouldn’t want to listen to the A5. I had also just heard the M3 in his bigger room. At the time I really liked Magico speakers and I wanted to hear what all the accolades were for. I asked him twice because I was really curious and they were right there in the smaller room and he refused to turn on the system choosing to discuss room acoustics instead. I haven’t been there since.
My apologies I have two pages of venders and contractors I’m dealing with as I’m in the middle of remodel and new construction here. I purchased some other audio gear, AV for another room. I did purchase from Precision Audio. And yes the were New. Serial #000629 and 630.Well, Precision Audio/Video is the only Chicago Magico Dealer in Chicago.
I MAY HAVE MISSED IT, but if you google The Listening Room in Chicago there is no listing for an audio dealer under this name. There is a Japanese type "Listening Room" listed under the "Exchange" in Chicago, but no audio store called the Listening Room. Again, maybe no listing under google???
I was going to talk to this dealer and make sure they could give you some assistance, but I don't see this dealer via Google and they definitely are not an authorized Magico dealer.
As a matter of fact, as you could not have bought the A5's new, because Precision Audio/Video is the only Magico dealer in Chicago, so whoever this dealer is must have sold you used A5s. Maybe there is something wrong with the used A5's that you purchased????
I didn’t really want to get into this because my current speaker is a B&W but yes I understand portended vs sealed. I owned a pair of Infinity sealed speakers they bought some time in the 90’s. funny thing is I had them in storage until recently, gave them a quick listen for the first time in two decades then sold them to clear out unused items I had collected. When I called Precision it was to inquire on a set of B&W 801D4’s. just to note I had recently also listened to a set of Wilson’s so I’m not really biased to the B&W brand. Just didn’t have a lot of time so I decided to go with the 801D4’s. As I stated before i expressed concern when he suggested the A5 in comparison to my 801’s. Told him what I liked about them My 801’s He assured me the A5 would outperform in those specific areas.DUHHHHH....I should have been paying more attention, last night I was watching two baseball games and the basketball game at the same time via two iPads and the tv while writing.
The 801s are 91db efficient, the A5's are 88db efficient. Not a great difference but you would be playing the volume at a higher level with the A5's vs the 801s.
THE 801'S ARE A DOWNWARD FIRING PORTED DESIGN. THE A5'S ARE A SEALED CABINET.
As we all know ported bass speakers and sealed cabinet speakers present bass in an entirely different manner. I won't go into my opinions on both designs if set up properly both designs can make GREAT sound, although the sonics and ESPECIALLY the bass is going to deliver an entirely different presentation.
I believe the 3 db efficiency, the ported vs sealed box, and set up has a LOT to do with this new A5 owner's initial experience. He may never like a sealed cabinet design speaker after being used to a ported design.
It takes times getting used to the sonic change when switching from ported to sealed cabinet bass, which imho is a totally different type of sonic presentation. ymmv.
Edit- This is why it is important to be working with the dealer who sold the A5s. A Magico dealer would have explained these mentioned points to set the proper expectations. In this case I am not sure who this pair of A5's was purchased from. It APPEARS that it was NOT from an authorized Magico dealer, if they were new or used and lastly working properly or not.
Yet, here you are, your first post on WBF (and on others - same A5 critical post), criticizing a remarkable product you clearly don't understand (you can't just drop them on a carpet, in what looks like an alcove and expect them to work). It doesn't even feel like you are asking for help, which you clearly need if you wish to hear what these speakers can do."...
I didn’t post on hear to ruffle anyones feathers. I really don’t do much of that. I have built a few show winning hot Rods and I stayed away from the message boards did my own thing and let Good Guys and the Gilmore Museum judges speak louder than opinion.
