Lampizator announcement: launch of our all new TOTL HORIZON DAC
John T
1,076
1,643
198
67
I've been following all that has been written here about the Lampizator Horizon. Been a solid state guy my entire life, back to Phase Linear, Empire TT, Revox A77 (Swiss Made) days. I'm intimidated by the tubes! But also intrigued. Maybe its the tube rolling aspect? I'm using a DV2 with Mephisto/Pandora, JA Pearl 20/20's, Taiko soon to come. Don't think I can get away from Gryphon. System is dialed in. I'm a Blues, Jazz, Classical guy, so the Tube aspect makes that more appealing. If anyone has some advice, input, wisdom, to someone that is thinking Horizon, please share your thoughts with this conundrum...John
Golum
1,814
2,577
405
Lausanne, CH
Hi John;
Nice that you've joined this thread, as I would say this is one of the key purposes of it - experience sharing but as well learning from others. As we are learning (or supposed to learn) day in day out, I strongly believe that Lampi community here can be and will be of tremendous help during your journey with tubed DAC. I've never ever experienced on the web more enthusiastic and helpful guys than those around here, so from that stand point there are no worries.
Tubes as such are glorious fun, sometimes pain as well, but fun and enjoying part always prevail as they just deliver magic.
Tube rolling - you can roll but as well you don't need to, as each single Lampi DAC leaves the factory with great sound with the tubes they have chosen from the current production. Tweaks with tube rolling can help you to further elevate the performance or steer the sound into direction which you would like it to go, to the certain extend, and on this pages you'll find description what guys achieved and with which tubes so it's super easy to follow and decide.
If you at the end of the day decide to make a step into unknown, I'm more then certain reward will be beyond magnificent :) .
Stay well;
G
MJG
44
207
225
61
Liechtenstein
Got mine on Sunday.
John T
1,076
1,643
198
67
Golum: Thank you for the kind and encouraging words. Once my Taiko arrives I will be able to focus on this potential new direction. Life is all about exploration and as you said "The unknown" I have certainly done my share of it. To be intimidated by a set of tubes would be a sad state of affairs. Thank You Again...John
"A guide is someone who helps build a raft and gets you across to the far shore
of the river, then he burns the raft"
Ancient Tibetan Buddhist Text
mr.gregdee
118
125
175
E.Sussex ,UK
gpoint-audio.com
Hooked the Horizon direct to Lampizator GM70 sound is excellent!
What pre did you left behind if I can ask ? Trying to establish the threshold for that. Txs.
rau
589
657
345
Wisconsin
I pulled a Vac Master out , I added it back yesterday to confirm and it sure sounds better without. But last night I added a Bent Audio TapX Autoformer preamp and it sounds excellent. This also allows me to run Horizon at 63 . I listened a few hours like this and it looks like this will be my choice . I suggest one try's there preamp before selling to confirm.
I totally agree. This too is system dependent. The Horizon preamp is fabulous and will provide sonic bliss to users who go direct DAC to Amp. For my system as good as it sounded without, I did prefer using my preamp and I have never had my Horizon gain at anything but 63 since I got it in February.
John T
1,076
1,643
198
67
Direct with any DAC as Steve interjected is so very much System Dependent. Obviously I have never played with the Horizon. My past and present experience is Preamp has worked in my systems. An amp like the Mephisto seems to perform better with a pre in the mix. I would love to hear from anyone who has experimented with the Horizon/Mephisto. Direct or with a pre...John
jbrrp1
340
510
163
As Golum noted, there is a magic in the music with tubes in the mix that is unmistakable, IME. And tube rolling is simply trying different combinations to season your overall soup just the way you like it! I love having that variable in hand for final system voicing - - beats cables, footers, etc. for this purpose, again IME.
Tuckia
474
736
180
Hi John T,
Our Extreme's should be shipping out this week :cool:. Not quite sure when my Horizon will deliver yet. Maybe June? So I can't say anything about the Horizon specifically, but I've owned a Pacific for over two years. Golden Gates before that.
I note your musical taste above. I'd say the Pacific is a truthful device that doesn't play favorites with music type. Some may have a perception of tube gear as being colored or conjuring a certain sound. This is wholly based on fact ;). Many tube amps over the years have played this role. Although some are more truthful than others, the speaker pairing is part of the equation and can't be ignored. Lampi dacs, or probably any other dac, aren't as subject to pairing synergy. OK, I'm completely ignoring the 242 tube/preamp pairing issue here, but that's a special case. Point is, consider a Pacific or Horizon for what it is, a good dac, not because it has tubes. That is first and foremost. After that you are welcome to slide down the tube rolling rabbit hole with the rest of us, if you wish. Knowing the rest of your system, I can't imagine you would be disappointed with either dac choice. They are just more soulful than others I've heard, because they let it pass through, not because they are making it.
Please share your thoughts on the Extreme after a few days. I think you are on the right path.
John T
1,076
1,643
198
67
Hi Greg,
Much obliged for the heads up! (You have quite a pedigree in regards to Lampizator) Also the specific nature as to how you explained "Good DAC Not because it has Tubes" The soulful aspect also caught my attention. I will share my observations on the Extreme. I really appreciate your insight...All The Best...John
christoph
4,689
4,077
825
Principality of Liechtenstein
Alrainbow
3,260
1,431
450
Big congrats on your H dac arrival.
new case looks great too , has the top tier look
makes one feel there looking down on the rest
I’m finally goiig to set up some music in terms of speakers down south now.
so more thought coming soon
jbrrp1
340
510
163
ctydwn
350
1,371
208
Fwiw, I've been told I am 15 on NA queue (Dec deposit) and have been pushed to mid-June (fingers crossed).
jbrrp1
340
510
163
Thanks for the perspective!
Willgolf
605
1,067
215
69
Gold Canyon, Az
Interesting, I was told there is only one queue and not a Europe or USA queue. If they are building 3 a week, you should have already received yours IMO.
Reactions: jbrrp1 and ctydwn
ctydwn
350
1,371
208
To nip this in bud, as I listen to the amazing Pacific…
I am in no relative rush for the Horizon (others might be more than me??). But of course massive anticipation and deposit money gone. Queue concept just interesting. I get being in the right place and of course the right person/manufacturer might make a difference. That said, I am sure I am exactly where Lampizator had me signed up last year relative to others with an early December 2021 deposit and as a Pacific owner.
Until the Horizon arrives, I will continue to enjoy my imho great sound. Ok. amazing sound. yes
Thanks to all for sharing their observations and raw thoughts on this hi end audio thread.
Really appreciate all the contributors. great mix of technical minutiae and levity.
