… and kaguras besides sfz as far as I can see from the picture.
With Amperex, United, and WE 242c. When I was there he was using Amperex. Next time.WE.
Also G1000 and G10
I saw no evidence that AF1 and AF3 premium models are too different. they’re basically the same. AF1 has air suspension feet that’s all. motor is claimed to be different but I suspect. AF2P and AF3P are quite the same for example. AF2P has air suspension feet also.I would not be at all surprise that the SME30 and AF3P are more different than alike. My comments are about the Air Force 1 that I directly compared to the American Sound AS2000. I have never heard, and did not comment on, the AF3P. It appears to be a very different design from the AF1.
AF1 & AF3 premium are very different turntables in design and sound quality aside from the same floating system they have nothing in common.I saw no evidence that AF1 and AF3 premium models are too different. they’re basically the same. AF1 has air suspension feet that’s all. motor is claimed to be different but I suspect. AF2P and AF3P are quite the same for example. AF2P has air suspension feet also.
Don’t know in what context you heard multiple 927s in or what was their condition but when properly setup it’s unbeatable. Many owners use EMT’s built-in phono stage which is mediocre at best maybe that’s what you heard in other places and poor setup. Tang’s EMT suffered from the AS tonearm which lacks resolution and bass, not a good match for the EMT who’s only shortcoming is very deep bass.I heard 4 EMT 927s and only liked Tang's. Pleasing is often a term used for color tinted valves here so that way it is not pleasing. What Tang's EMT did was it had the best PRAT I heard. Just awesome timing. It made you break into an Elvis, really had the groove, extremely lively. It is big sounding but so is Garrard, and just being big sounding is not the thing, it's rhythm and timing is great. It's main drawback was lack of nuance for classical, in inner note inflections as well as in separation of instruments. Tang later tried many experiments including using vdh to increase nuance but by reports don't think he succeeded. For certain music it was awesome and if I had an expensive TT harem, it will be first choice for a second table, i.e. one that is dedicated as first choice to play certain music, but cannot play all music so can't be a choice if one owns only one TT.
In vintage idlers the Silbatone WE room in Munich, where Schick and Schroeder themselves man the analog, have also played modded Commnwealth and dual platter lencos which have been the best analog in Munich (without benefit of isolation, though they have a tape deck and till 2018 a dCS there to compare to). In fact if I had the dough I would have offered them the money in 2019 for the dual platter lenco with vdh strad to take back after the show. Picture is at the bottom of the linked page http://zero-distortion.org/munich-2019/
It does lack resolution comparing to the American Sound and also has different kind of bass. The EMT banana arm and Ortofon 297 that came with it lack resolution even more.Don’t know in what context you heard multiple 927s in or what was their condition but when properly setup it’s unbeatable. Many owners use EMT’s built-in phono stage which is mediocre at best maybe that’s what you heard in other places and poor setup. Tang’s EMT suffered from the AS tonearm which lacks resolution and bass, not a good match for the EMT who’s only shortcoming is very deep bass.
david
Resolution or Elvis…in Tang’s case, he has bothIt does lack resolution comparing to the American Sound and also has different kind of bass. The EMT banana arm and Ortofon 297 that came with it lack resolution even more.
no they’re not. add a good isolation platform under AF3P and you’re good to go.AF1 & AF3 premium are very different turntables in design and sound quality aside from the same floating system they have nothing in common.
david
Aside from floating platters and vacuum which other completely different tts also have please point out a single commonality between the two models, physically or sonically. I deal with both tts regularly and even kept one of them, they are very different products.no they’re not. add a good isolation platform under AF3P and you’re good to go.
I’m also a big fan of the EMT 927, which I first had experienced at David’s home. The built-in phonostage is fun, but as David mentioned, an alternate solution can be preferable.
I have played with the fully reconditioned 927st from the folks in Germany for over a year now. A little mental, I recently received a fully reconditioned 927f from the kind fellow in The Netherlands.
To concur with Ked, I completely understand his Elvis impression .
vbw,
-a
you should explain first how different they are cause as you can see below you commented before me that they're totally different.Aside from floating platters and vacuum which other completely different tts also have please point out a single commonality between the two models
and you should explain their being extremely different cause we were discussing if SME 30/12 and AF1 have a similar dampened sound signature or not. so the case is not about slight differences, it's about day and night differences between AF3P and AF1. so big that we should be convinced even a totally different approach like SME 30/12 can sound like AF1 while AF3P can't. I should make a note of that I deal with techdas turntables too. and I'm also very familiar with SME turntables and tonearms.AF1 & AF3 premium are very different turntables in design and sound quality aside from the same floating system they have nothing in common.
This is why my friend who had multiple SME tables didn't pair them with SME arms, but usually Graham Phantom or Triplanar. I didn't like these combos much.
I despise the TD124, but the Garrards are fun. Just not as a primary table.
Pleasing is fine. Pleasant on the other hand is a kiss of death. The TD124 is pleasant.
What do you think is meant by the phrase “reproducing the recorded information of the background noise“? I find the phrase very confusing.
I read the comment as meaning this Ron.Does this mean the ambient noise in a venue (for example, coughing, glasses clinking, air conditioning) before musicians start playing?
Thank you. But there is no way to know the meaning intended by the author.
We can build competing arguments based upon the clause just for fun, but there is no principled support for the opinions underlying those arguments -- unless one stipulates in advance the interpretation of the clause that one is adopting and upon which one's following argument is based.
I merely employed Mr Holms consideration Ron :
"How often have I said to you that when you have eliminated the impossible, whatever remains, however improbable, must be the truth? “
For my part the only thing that made sense.
. . . he wants to achieve a digital like silence in both a low noise floor to reveal more ambient information embedded on the recording, and also a digital like silence between music tracks devoid of vinyl surface noise, clicks and pops. The fact that he did not express this clearly leaves it open to interpretation and confusion. It remains clear however, that the turntable was designed during the digital era and that something about digital silence captured his interest.
It was this post of yours that I replied to nothing to do with anything SME.you should explain first how different they are cause as you can see below you commented before me that they're totally different.
and since you deal with techdas, would be nice to know in what capacity as well, it should be very easy for you to answer the question and back up your claim and don't try to change the subject please "Aside from floating platters and vacuum which other completely different tts also have please point out a single commonality between the two models, physically or sonically."I saw no evidence that AF1 and AF3 premium models are too different. they’re basically the same. AF1 has air suspension feet that’s all. motor is claimed to be different but I suspect. AF2P and AF3P are quite the same for example. AF2P has air suspension feet also.
