And a special adapter at that, with different resistor values to the rgn2004 family as the PV200/600 runs stronger, measuring closer to rgn4004I prefer it over Taka Less than 100€, but you need to use an adapter.
Good to know, Mark. Could you point to exactly what you purchased?And a special adapter at that, with different resistor values to the rgn2004 family as the PV200/600 runs stronger, measuring closer to rgn4004
Now I need to ask about this Soviet BO-188.it’s very good Etor, certainly one of the leading solid plate options along with the soviet bo-188 but lacks the magic of any of the 4 volt mesh tubes.
Westinghouse vu71? I have one as well as Tak.Thanks @takacs75 and @Sablon Audio. I briefly tried the VU71 a few days ago and enjoyed what it's warmth did with jazz. @takacs75 have you tried the VU71 and is it just as warm as the Tak 274B since you chose it as a comparison?
Have a look at some of my posts on the baltic 3 thread Etor, have covered maybe 20 different rectifiers. Different dac I realise but you can pick up some relative differences, both objective and subjective, between the various tubes.Now I need to ask about this Soviet BO-188.
I had it custom made but if you order an ax50 adapter off the chinese ebay seller (xulingmrs?) then you can specify the exact tube to be used and he will deploy the appropriate resistor values.Good to know, Mark. Could you point to exactly what you purchased?
Ah, that's where the discoveries are hiding these days. Consider it bookmarked.Have a look at some of my posts on the baltic 3 thread Etor, have covered maybe 20 different rectifiers. Different dac I realise but you can pick up some relative differences, both objective and subjective, between the various tubes.
My conversation with Lukasz when asking about Visseaux 6n7gt;Response from Lampi:
Hello,
this tube is perfect, I have no idea where the objections come from.
Best regards
?ukasz Fikus
Issue resolved
My question; Is it possible to use Visseaux 6n7gt when using balanced outputs?
Lukasz answer; Yes.
My reply; Despite the common cathode?
Lukasz reply; OOps, I read 6SN7 not 6N7, in this case - you can not
Anyway, since you are using them with XLRs connected I assume it's possible.
Thank you for your help!
YES YES YES YES - great proposal!!!Talking of adapters, what we really need is the Yamamoto genius ux4 / b4 combined socket which allows both regular 5u4g and pre ww2 B4 type tubes to be used in the same socket. Great materials and shake off lossy adapters. @Lukasz "Lampizator" Fikus - would this be a viable build option for you to incorporate?
No, I don’t know that tube.Thanks @takacs75 and @Sablon Audio. I briefly tried the VU71 a few days ago and enjoyed what it's warmth did with jazz. @takacs75 have you tried the VU71 and is it just as warm as the Tak 274B since you chose it as a comparison?
The OS1 tubes and the adapters need a lots of time to burn-in. 150-200 minimum I use them with Mullard ecc32 with great result.I am now rocking the new kids on the block: the Tungsram tubes all the kids are raving about…. I was using the 6384 so competition is stiff. Still no verdict. I couldn’t get the ECC32 to work just right with the 6384. There was a loss of detail. So I was using the adapted ECC31, which sounded perfect. I have real nice Military grade ECC32 labeled 181. I will throw them back in and see if they pair well with these Tungsram, as others have suggested….
So far, the Tungsram are very full bodied. A bit more bass than the 6384. More power, it seems.
Let’s let em run in and see what we see. I trust the Gollum. He has the precious.
This is not a surprise. I'm often asked, which is better the 31 or the 32? The truth is that technically they should sound the same but it's important to remember that no pair of 70 year of tubes is guaranteed to sound identical even if they are the same exact model. So if a particular pair of 31s sounds better than 32s, it does not mean one is "better" than the other. The difference could easily have gone the other way. It is true, adapters might (or might not!) contribute some to the equation but it will be relatively insignificant compared to the bigger picture.The driver is dialed in via ECC32 & 31. Surprisingly, the 31 w/ adapters works better in certain configurations.
Agree that the KT170's were just an OK good tube but again, these things are always system related and personal preference dependent. I sold mine a long time ago. For me, nothing does piano like the Mullard ECC31/32 - Mullard EL34 combo with a great rectifier. Re rectifiers I have tried all the usual suspects. I sold my WE 274b because while the mids and highs were mucho splendido, the bass was a bit of a disappointment. It's plummy and full rather than tight and reminds me of the kind of tube sound people with horns aspired to 30 years ago and that's just not for me (Uh Oh, incoming...). The Takatsuki 274b is in some ways the opposite of the WE in that the bass is full and tight, but it is overly dark with my current other tubes (although I loved it with the Sylvania B65 metal base 6SN7 for example or the chrome domes- yes, pairing matters! The Tak is also a good fit for the TungSol BGRP since it helps fill out that tube's bottom end and helps warm up the top as well). My Tak (like new) is looking for a good home and is for sale at a great price (see classifieds!). I currently love the GEC U52 but only the staggered plate version (like the Cossar K53) which is extremely hard to find. However, the GEC U52 is very expensive ($600+) and the truth is there are so many wonderful rectifiers (all under $100 i.e., American Amperex 5U4G, Brimar 5U4G, RCA 5U4G 4V AZ1 mesh, with adapter) I could be happy with any of them. FYI- a wonderful Horizon tube set at a great price with many of these tubes can be found here: https://www.usaudiomart.com/details/649979380-lampizator-horizon-tube-set/Both audioquattr and I did not like the KT 170s as well as other KTs - he had 88 120s in his. We ended up with mullard el34 and ecc 31 drivers as compared to KTs
Great report Marty. You are very articulate and should write reviews. I can always follow your experiences.This is not a surprise. I'm often asked, which is better the 31 or the 32? The truth is that technically they should sound the same but it's important to remember that no pair of 70 year of tubes is guaranteed to sound identical even if they are the same exact model. So if a particular pair of 31s sounds better than 32s, it does not mean one is "better" than the other. The difference could easily have gone the other way. It is true, adapters might (or might not!) contribute some to the equation but it will be relatively insignificant compared to the bigger picture.
I've got some pentode EL50's and EL51s to try pending shelf surgery. (With adapters, these are tall tubes and I need to lower the shelf for my Horizon to accommodate them so my cabinet does not burst into flames.). And finally, I'm going to try some high end 4V mesh rectis (RGN 2004) because Goran doesn't think I'm spending enough money on tubes .
